38k Cabinet (INTEL) W/O Monitor, Graphics card, Speaker, UPS, Keyboard and mouse.
Vensanga
1. What is the purpose of the computer? What all applications and games are you going to run?
Ans: Mid-range gaming like Fifa 14, Need for Speed Rivals, Nba2K14, Mortal Combat Komplete Edition, Grid etc... multimedia, photoshop (starter). PS: Will be using for the next 4 years.
Ans: 38k will be able to extend upto 2k.
3. Planning to overclock?
Ans: No
Ans: win 7
Ans: 1tb or 2tb.
Ans: Currently having Samsung 19inch. Will buy Dell S2240L later.
Ans: Will not require Monitor, Graphic Card (will buy after 2-3 month), Speaker, UPS, keyboard and mouse.
Ans: Within 1-2 week.
Ans: Yes,will assemble myself.
Ans: Aizawl, Mizoram (North-east). Will but from online, I have checked Mdcomputers, theitwares and theitdepot.
Ans: I have shortlisted here...
CPU : Intel Core i5 4570
Motherboard : Gigabyte B85M-D3H
RAM : Corsair Vengeance 4 GB 1600 MHz
Cabinet : Corsair Carbide SPEC 01 -3800
HDD : Seagate 1tb or 2 tb
PSU : Corsair GS600 (or any other)
DVD Writer : Any
CPU : Intel Core i5 4570 -14000,
Motherboard : Gigabyte B85M-D3H -5500,
RAM : Corsair Vengeance 4 GB 1600MHz -2600,
Cabinet : Corsair Carbide SPEC 01 -3800,
HDD : WD Caviar Blue 2TB -5800,
PSU : Seasonic SS520GM -5900,
DVD Writer : Asus 24B5ST DVD-RW -1100.
TOTAL -38,700.
mastermunj
TOTAL -38,700.
By spending less on HDD (opt for 1TB) and on PSU (S12 520W = 4600), he can save more than 3,000, which he can use for better CPU & Mobo.
Vensanga
Vensanga
TOTAL -38,700.
Thanks for the suggestion....
Yes, you are correct. If I go for 1tb HDD and PSU as you suggested that way I can save more for the Monitor and later add another 1tb HDD and also another 4Gb RAM as well. And how about Corsair PSU CX500, CX600, VS550, the price seems to be lower than Seasonic S12II 520 (Rs.5175@Flipkart).
Cilus
laborare est orare
Don't go for the Corsair VS series, they are not good, If you want cheaper option, then opt for Antec VP550P PSU which is retailing around 3.6K.
Vensanga
Vensanga
Thanks for the suggestion, I have make an order in Itdepot, and I will be needing Graphic card so will post again after 1-2 months for your suggestion. here are my list....
Intel Core i5-4570
Gigabyte GA-B85M-D3H
Corsair 4GB (1 x 4GB) DDR3 1600MHz
Corsair Carbide Series SPEC-01
Seasonic 520W Power Supply (S12II-520)
Western Digital Caviar Blue 1TB SATA
Asus 24x Sata Internal DVD Writer
Cooler Master 120mm Red LED Fan (2)
