Window XP installation problem
oh yeah
im installing XP using Dos i hav commanded "D:\i386\winnt" then blue screen appears and it says
An internal Setup error occurred.
Could not find a place for a swap file.
Setup cannot continue. press ENTER to exit.
Please tell me wat 2 do and how 2 do.
Please help me u can also contact me at
mohsin_a_b@yahoo.com
or
mohsinonfire@gmail.com
PrinceHeart
Make a Win 98 Boot floopy with CD Support.
Download the Windows 98 SE boot disk from Bootdisk.com
Insert both Floppy n WinXP CD inside floppy n cd drive respectively.
Change Boot Preference to Floppy in Bios.
Restart PC.
Boot the PC from floopy.
Then try to install WinXP.
Note: Can do the same if D drive is a hard disk partition and WinXP files are dumped in a folder.
Hope it helps.
Cheerz
O
oh yeah
thank u prince but 1 more problem my laptop on which im installing dosent have floppy drive....;
can i boot my pen drive.
krates
Be CoOl rAp RuLeZ !!!
Don't Try To Install It From Dos Just Insert Your Cd Select First Booting Device As cd Rom Then The Setup WIll Start Follow The Instructions And You Are Done
PrinceHeart
oh_yeah - Just make a bootable startup cd and boot from it 1st and then install winxp from ur hard disk - or u can always burn the winxp installation and make a bootable OS disc and install directly from CD - as told by The Unknown.
Hope it helps.
Cheerz
Edited the Nick ID.
nileshgr
PrinceHeart said:
oh_yeah - Just make a bootable startup cd and boot from it 1st and then install winxp from ur hard disk - or u can always burn the winxp installation and make a bootable OS disc and install directly from CD - as told by The_Unknown.
Hope it helps.
Cheerz
u guys always misspell me. my id is The Unknown.
