[URGENT Help Required] Best Air Conditioner?
Hi Guys,
I am in search of a good A.C (Split).
Could you please suggest me the best one's.
My requirements are like :
Fast cooling(As I am from rajasthan & normal temp varies from 44-48)
Low Electricity consumption (5 star BEE rated)
Long Run (Best suitable brand which provides least maintenance probs).
I have gone thru a number of brands and have liked Hitachi & LG.
What do ya guys say.
I would appreciate if you can help me wth Brand & Model no as per my needs.
Thanks a ton in advance.
pulkitpopli2004
only hitachi... or ogeneral.. i wont suggest any other also they wudn;t be successful at such temp..
i purchased hitachi 4 start yesterday
K
kyldeepbhardwaj
I compared the prices today but HITACHI if far too expensive for my budget.
My budget is 20-25k/1.2-1.5L.
I can expand it to 5k more but what's the best option I should go for?
Please help...............
avichandana20000
hitachi logicool
LRAU014KPD
SPLIT AC - 1.2T LOGICOOL SAC - LRAU014KPD (W/O CONN.KIT) 25000/-
it is the NET PRICE. you will get in 22k. but installion cost, Electricity office cost(for extra meter) will incurr
My colleague has bought it for 22k & with those costs completed the package in 30k.
yamanjain
+1 for voltas. Actually they sell a Toshiba compressor with external dabba branded by Voltas. They are much more cheaper than Hitachi, and reasonable enough cooling,
Disclaimer: I only have first hand experience with Career, Samsung and Voltas. All 3 are fairly the same (all are good) in terms of experience. Never had any problems.. Never had a hitachi..
ithehappy
At OP, you want a good AC? Then you should go for either Hitachi or Blue Star or Daikin. Frankly I don't believe the other remaining brands. And your budget is good 25k, both Hitachi or Blue Star is inside the range, check their websites and choose one.
Personally, I purchased a 1.1 T Summer QC and I am damn happy with it.
Tenida
Gadget Freak
+1 for hitachi & blue star.Buddy go for good company as suggested by ithehappy because '' I believe good quality rewards with higher savings''.Best of luck for ur purchase. :)
