Urgent help...Buying a 48" LED TV.
aroraanant
Explorer
I am planning to buy Samsung 48H5100, getting locally for 67.25k(final price after bargaining).
Is there any other better option in that budget?
I don't any more bargaining is possible on the above mentioned price atleast in my area, what do you guys think should be the best price of the above model?
And should a wait for diwali festive offers, as people say there would be good offers for sure during festive season.
Please reply soon, your suggestions are most welcomed and very necessary for me.
Minion
I will suggest you not to get large budget tv.Instead get something smaller with better feature.
aroraanant
aroraanant
Explorer
The problem is that I have to place it in my drawing room which is very huge, the hall size is 25x15 + the dinning room is attached with it having size of 15x12, if we don't consider dinning room also then still atleast there should be television with a screen size of minimum 48" or more, infact 50" or 55" will do a much better job but then their price is just too high and there is no need of spending that much.
What do you say now Minion.
aroraanant
aroraanant
Explorer
Bought Samsung 48H5100 for 67.3k from a local store 2 days back.
I will surely post a small review when I will get time
