Suggest Blue LED 120MM fan
saikiasunny
This one(better than xtraflo and excalibur) -
Cooler Master 90 CFM Blue LED Cooler | Cooler | Flipkart.com
gameranand
Living to Play
I was going to recommend Deepcool XFAN120L/B but unfortunately its out of Stock there, so get the one previously suggested. :)
bajaj151
Both deepcool fans are available on ebay.
Please suggest : Which one will look good and which one will perform better ?
1) Deepcool Ice Blade Fan 120mm Cabinet Cooling Fan Semi Black With Blue LED + BILL | eBay
2) Deepcool XFAN120L/B 120mm Cabinet Cooling Fan Transparent With Blue LED + BILL | eBay
The Incinerator
Both the Deepcools are under performer when compared to this Cooler Master 90 CFM Blue LED Cooler | Cooler | Flipkart.com
Its the best 120mm out there.
saikiasunny
Sorry my bad, it was not the xtraflo but the blademaster.
But Have a look at this
120 mm Fan Roundup, Part 2: 1350 RPM or Higher Rotation Speed. Page 4 - X-bit labs
matches the kama flow 2
The Incinerator
CM Standard Blue LED - 90CFM @ 2000RPM (Long-life Sleeve Bearing less noisy compared to ball based bearings,not very long lasting needs maintenance and prone to changes due to thermal inconsistency)
CM Excalibur - 85.6 CFM @ 2000RPM (Barometric Ball Bearing : read better build,long lasting and silent)
CM Xtraflow - 82.9 CFM @ 2000RPM (Long Life Sleeve)
Now if you want move more air then its a no brainer but to buy the CM Standard Blue. CM Excalibur though robustly built costs an insane Rs 1900 for a 120mm fan.CM xtraflow give it a miss.
saikiasunny
First the sickleflow produces 69.9 cfm and matches the scythe kama flow 2. It easily outperforms the excalibur and blademaster(predecessor of the xtraflo)
No need to go for the excalibur.
And afaik the blue xtraflo is not available in india.
So its your choice.
