strange system standby problem.please help
Discussion in 'Software Q&A' started by quan chi, Sep 23, 2009.
Thread Status:
  1. quan chi
    quan chi mortal kombat
    Jul 20, 2006
    1,888
    19
    38
    hi guys.
    well from few days i am experiencing these problems.
    1.sometimes when i restart the system through windows.it just goes to kinda 'stand by mode'.i mean even if i move the mouse or press any button it does not show any response and remain in that condition only until i restart by pressing the restart button.
    2.some games which used to work better earlier now slows down sometimes or even stutter unecessarily sometimes.
    3.to open 'my computer' or 'my documents' by double clicking through desktop takes a noticeable amount of time.it takes more time to open.
  2. Krow
    Krow Crowman
    Mar 6, 2008
    4,330
    9
    0
    New Delhi
    Is there free space on your OS drive? Sure there are no viruses on your PC? Use CCleaner and rid your PC of all the muck and report.
  3. OP
    quan chi
    Jul 20, 2006
    1,888
    19
    38
    yeah did almost everything.
    the games also shows some strange behaviour.( in between sometimes)
    i mean if it does not stutter then sometimes it behaves in a
    'wavy manner'.i mean it works smooth then it becomes a bit slow (no stutter.like in slow motion for a fraction of a sec) then again to normal.like this it continues.
    so it gives kinda to and fro motion to the charecter even though it is moving linearly.
  4. Krow
    Krow Crowman
    Mar 6, 2008
    4,330
    9
    0
    New Delhi
    Try uninstalling and updating your gfx drivers and then report on games.
  5. OP
    quan chi
    Jul 20, 2006
    1,888
    19
    38
    checked that also but no improvement.there is no fixed or specific place where it starts.it just starts randomly at anytime.but it is not observed at the starting of any game.it occurs after some time in between.
    though it is minor but still it is noticeable.
    btw i am thinking of installing win7 on my 'e' drive to test .i have currently windows xp sp3.
    i have never before installed a dual boot system.
    can you please tell me.
    1.if i install win7 on e drive then will the files present on e drive will get deleted.
    2.after that if i want to uninstall win7 then what should i do?
    3.is it a safe process.
  6. OP
    quan chi
    Jul 20, 2006
    1,888
    19
    38
    now this is damn irritating and too much.people with similar system as mine can play burnout paradise without any problem.
    but in my system this game as i have mentioned previously lags very often even in the low settings.
    mostly the lags are observed when using a car on bike the lag is less seen.
  7. Krow
    Krow Crowman
    Mar 6, 2008
    4,330
    9
    0
    New Delhi
    Check system temps. kay, now please post your config. Along with OS and Service Pack. 32bit or 64?
    To install win 7 is safe AFAIK, but to uninstall you will have to format, so Install in a free drive. I recommend u stick to XP as it worked for me in XP 32 bit with onboard ATI Radeon HD3300 gfx with 640MB shared DDR2 VRAM.
  8. OP
    quan chi
    Jul 20, 2006
    1,888
    19
    38
  9. Krow
    Krow Crowman
    Mar 6, 2008
    4,330
    9
    0
    New Delhi
    Well Quan Chi, P4 is not really fit to run that game, is it? I had a similar rig, with iball stock 400W psu only difference was Galaxy 6600 256MB PCIe.
    All I can suggest to you is that you try the GameBooster.
    Link:
    http://www.iobit.com/gamebooster.html
    Posted again:
    ADD: In my rig, the game used to crash frequently although it maybe cz my 1GB memory module was faulty. Did you run memtest 86+ on your RAM?
  10. OP
    quan chi
    Jul 20, 2006
    1,888
    19
    38
  11. Krow
    Krow Crowman
    Mar 6, 2008
    4,330
    9
    0
    New Delhi
    He had a rig with a 3.7GHz P4? Nice OC he did. Try GameBooster and check if there is any difference.
  12. OP
    quan chi
    Jul 20, 2006
    1,888
    19
    38
    lol dude i forgot to mention mine is also oced to 3.35ghz.:wink:
    btw checked ram with memtest seems to be ok.
    i think the problem is kind of different please read my post 1 point1 again.this happened today also.i cant find out whats causing this strange problem.defragged the drives also but still no improvement.
  13. Krow
    Krow Crowman
    Mar 6, 2008
    4,330
    9
    0
    New Delhi
    In my experience I have noticed that such tings do happen to XP after some time into the installation. Say, six months after you installed XP the PC becomes slower and progressively so. Try defragging your registry. Also, do the my comp and docs take time to open all the time? Or is it just at startup?
    Other queries :
    How many entries are there during startup? (start>run>msconfig>startup tab)
    How many processes are running after your rig has booted up fully?
  14. OP
    quan chi
    Jul 20, 2006
    1,888
    19
    38
    yes thats what i am saying.it takes time to open all the time even after the startup.
    but the folders present inside them opens normally.
    20entries.
    Logfile of HijackThis v1.99.1
    Scan saved at 11:58:09 PM, on 9/23/2009
    Platform: Windows XP SP3 (WinNT 5.01.2600)
    MSIE: Internet Explorer v7.00 (7.00.6000.20627)
    Running processes:
    C:\WINDOWS\System32\smss.exe
    C:\WINDOWS\system32\winlogon.exe
    C:\WINDOWS\system32\services.exe
    C:\WINDOWS\system32\lsass.exe
    C:\WINDOWS\system32\nvsvc32.exe
    C:\WINDOWS\system32\svchost.exe
    C:\WINDOWS\System32\svchost.exe
    C:\WINDOWS\system32\spoolsv.exe
    C:\WINDOWS\Explorer.EXE
    C:\Program Files\Analog Devices\Core\smax4pnp.exe
    C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe
    C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
    C:\Program Files\Common Files\Real\Update_OB\realsched.exe
    C:\WINDOWS\system32\rundll32.exe
    C:\WINDOWS\system32\RUNDLL32.EXE
    C:\WINDOWS\system32\ctfmon.exe
    C:\WINDOWS\msa.exe
    C:\DOCUME~1\Admin\LOCALS~1\Temp\b.exe
    C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\mdm.exe
    C:\Program Files\Norton AntiVirus\Engine\16.0.0.125\ccSvcHst.exe
    C:\Program Files\CyberLink\Shared files\RichVideo.exe
    C:\WINDOWS\system32\wscntfy.exe
    C:\Program Files\uTorrent\uTorrent.exe
    C:\Documents and Settings\Admin\Desktop\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://search.yahoo.com/search?p=
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
    R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
    O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
    O2 - BHO: XML module - {500BCA15-57A7-4eaf-8143-8C619470B13D} - C:\WINDOWS\system32\msxml71.dll
    O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O2 - BHO: Symantec Intrusion Prevention - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files\Norton AntiVirus\Engine\16.0.0.125\IPSBHO.DLL
    O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\PROGRA~1\MICROS~2\Office12\GRA8E1~1.DLL
    O2 - BHO: SingleInstance Class - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\Program Files\Yahoo!\Companion\Installs\cpn\YTSingleInstance.dll
    O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
    O3 - Toolbar: DAEMON Tools Toolbar - {32099AAC-C132-4136-9E9A-4E364A424E17} - C:\Program Files\DAEMON Tools Toolbar\DTToolbar.dll
    O4 - HKLM\..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\Core\smax4pnp.exe
    O4 - HKLM\..\Run: [VistaDrive] C:\WINDOWS\VistaDrive.exe
    O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Nero\Lib\NeroCheck.exe
    O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
    O4 - HKLM\..\Run: [GrooveMonitor] "C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe"
    O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
    O4 - HKLM\..\Run: [LanguageShortcut] "C:\Program Files\CyberLink\PowerDVD\Language\Language.exe"
    O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
    O4 - HKLM\..\Run: [USB Gamepad] C:\WINDOWS\USB Vibration\dr100&110\USB Gamepad.exe -boot
    O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
    O4 - HKLM\..\Run: [UnlockerAssistant] "C:\Program Files\Unlocker\UnlockerAssistant.exe"
    O4 - HKLM\..\Run: [UpdatePDRShortCut] "C:\Program Files\CyberLink\PowerDirector\MUITransfer\MUIStartMenu.exe" "C:\Program Files\CyberLink\PowerDirector" UpdateWithCreateOnce "Software\CyberLink\PowerDirector\7.0"
    O4 - HKLM\..\Run: [BluetoothAuthenticationAgent] rundll32.exe bthprops.cpl,,BluetoothAuthenticationAgent
    O4 - HKLM\..\Run: [nwiz] C:\Program Files\NVIDIA Corporation\nView\nwiz.exe /install
    O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
    O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
    O4 - HKCU\..\Run: [DAEMON Tools Lite] "C:\Program Files\DAEMON Tools Lite\daemon.exe" -autorun
    O4 - HKCU\..\Run: [PopRock] C:\DOCUME~1\Admin\LOCALS~1\Temp\b.exe
    O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
    O4 - Startup: Adobe Gamma.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
    O4 - Global Startup: Shortcut to RocketDock.lnk = C:\Program Files\RocketDock\RocketDock.exe
    O4 - Global Startup: Shortcut to sidebar.lnk = C:\Program Files\Windows Sidebar\sidebar.exe
    O8 - Extra context menu item: &Highlight - C:\WINDOWS\WEB\highlight.htm
    O8 - Extra context menu item: &Links List - C:\WINDOWS\WEB\urllist.htm
    O8 - Extra context menu item: &Web Search - C:\WINDOWS\WEB\selsearch.htm
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
    O8 - Extra context menu item: I&mages List - C:\WINDOWS\Web\imglist.htm
    O8 - Extra context menu item: Open Frame in &New Window - C:\WINDOWS\WEB\frm2new.htm
    O8 - Extra context menu item: Zoom &In - C:\WINDOWS\WEB\zoomin.htm
    O8 - Extra context menu item: Zoom O&ut - C:\WINDOWS\WEB\zoomout.htm
    O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
    O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\Office12\REFIEBAR.DLL
    O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
    O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
    O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
    O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
    O11 - Options group: [INTERNATIONAL] International*
    O11 - Options group: [TABS] Tabbed Browsing
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/microsoftup ... 0188616578
    O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftup ... 0188440531
    O16 - DPF: {D1E7CBDA-E60E-4970-A01C-37301EF7BF98} (Futuremark SystemInfo) - http://www.yougamers.com/systeminfo/FMSI.cab
    O17 - HKLM\System\CCS\Services\Tcpip\..\{FF7088AA-EDD6-4888-8F9E-D3D1661C4DB1}: NameServer = 121.241.40.26 111.125.192.11
    O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\PROGRA~1\MICROS~2\Office12\GR99D3~1.DLL
    O18 - Protocol: ms-help - {314111C7-A502-11D2-BBCA-00C04F8EC294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll
    O18 - Filter hijack: text/xml - {807563E5-5146-11D5-A672-00B0D022E945} - C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE12\MSOXMLMF.DLL
    O20 - Winlogon Notify: dimsntfy - %SystemRoot%\System32\dimsntfy.dll (file missing)
    O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\wpdshserviceobj.dll
    O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
    O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Nero\Lib\NMIndexingService.exe
    O23 - Service: Norton AntiVirus - Unknown owner - C:\Program Files\Norton AntiVirus\Engine\16.0.0.125\ccSvcHst.exe" /s "Norton AntiVirus" /m "C:\Program Files\Norton AntiVirus\Engine\16.0.0.125\diMaster.dll" /prefetch:1 (file missing)
    O23 - Service: NVIDIA Display Driver Service (nvsvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
    O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared files\RichVideo.exe
    O23 - Service: TuneUp Drive Defrag Service (TuneUp.Defrag) - TuneUp Software GmbH - C:\WINDOWS\System32\TuneUpDefragService.exe
    amongst them i have removed msa.exe and b.exe.
  15. Krow
    Krow Crowman
    Mar 6, 2008
    4,330
    9
    0
    New Delhi
    From startup remove:
    richvideo.exe and all other power director related processes
    nerocheck.exe
    realsched.exe
    reader_sl.exe
    groovemonitor.exe
    ctfmon.exe
    For disabling ctfmon, u can right click on EN button next to system tray and in settings disable it. Use tuneup to defrag your registry.
    Uninstall:
    Yahoo! Toolbar
    Daemon Tools Toolbar
    Cyberlink Power Director (if you dont need it)
    Real Player (you may use VLC only instead)
    Also, I recommend you uninstall MS Office 2007 and use Office 2003 or even better OpenOffice.org 3.1. Do you use Word for heavy purposes? Do u need all other office apps like powerpoint and excel? Do you make charts in Word? If no for all three, you can install AbiWord, which is a 5mb setup and is a simple and solid word processor.
Thread Status:
Share This Page
