1. Hi Guest
    We are running a survey about laptop service in India, and we'd love your inputs. Please help us improve the quality of laptop servicing, and if you've had any bad experiences, now is the time to be heard.
    Take the survey
Strange DSL disconnect problem ???
Discussion in 'QnA (read only)' started by rishitells, Jul 23, 2009.
Thread Status:
  1. rishitells
    rishitells Always in Dreams...
    Dec 27, 2006
    221
    0
    0
    New Delhi, India
    I have a BSNL DataOne DSL Plan (256 kbps) and i use windows Xp. Till yesterday, the connection was working fine but now the problem is-
    When i connect to internet via dsl modem, it works fine for 5-10 minutes, then suddenly i see a strange change in my computer ( windows switches to classic theme, then becomes normal ! ).
    And after it, the connection doesn's work at all. And worse, when i try to disconnect the connection, it never disconnects. At last i have to shut down the pc. What is this?
    Is this a virus/malware attack or something like this?
    I use Avast! anti virus, and during the connection, there was some DCom Exploit attack, And i disabled the DCom feature by software. But the problem still persists!
    Please help me, i am unable to access my own connection. :cry:
  2. paroh
    paroh Member
    Jul 28, 2008
    850
    0
    16
    I decided to write this entry for the sake of those ppl who want to get their computer back to normal. All you got to do is to close port 135 and 445. So here what you got to do:
    How to close port 445
    Start Registry Editor (Regedit.exe) by clicking Start menu, and then click the Run icon.
    In the small box that Opens, type: regedit then click the OK button.
    The Registry Editor will now have opened
    Locate the following key in the registry:
    HKLM\System\CurrentControlSet\Services\NetBT\Parameters
    In the right-hand side of the window find an option called TransportBindName.
    Double click that value, and then delete the default value, thus giving it a blank value.
    The you must now navigate to the following registry key:
    HKEY_LOCAL_MACHINE\Software\Microsoft\OLE
    You will see there is a String Value called: EnableDCOM
    Set the value to: N (it should currently be Y)
    Close the Registry Editor.
    Shutdown and Restart your computer.
    You could also disabled NETbios. But found that by disabling these two, my computer get back to normal without re-formatting my computer etc. Hope you can get rid of this faulting application svchost exe problem. Good Luck!!
  3. OP
    rishitells
    Dec 27, 2006
    221
    0
    0
    New Delhi, India
    It worked!! Thanks a lot friend.
    Anyway, what actually the problem is? Is it any security flaw or a virus attack?
  4. paroh
    paroh Member
    Jul 28, 2008
    850
    0
    16
    It is something like exploiting the open port (SECURITY FLAW)
  5. piyush.ml20
    piyush.ml20 The assaulter
    Aug 8, 2008
    37
    0
    0
    2 gud man.it worked 4 me 2.
    but i have 2 que -
    1) my avast antivirus is still showing that it has blocked dcom xploit attack.
    2) n now my dsl link goes off every 10 minutes.
  6. awww
    awww Banned
    Apr 28, 2009
    72
    0
    0
    this is a flaw with windows
    updating windows will also work for this
    if you dont want to work with registry like paroh mentioned
  7. piyush.ml20
    Aug 8, 2008
    37
    0
    0
    is other std ports like 25,80 etc r also vulnerable.
  8. piyush.ml20
    Aug 8, 2008
    37
    0
    0
    paroh plz mention its cons too dude.i try this at my shop also regarding security flaw.
    but what it did is it stop my networking n it take hrs 2 find d problm.
    Posted again:
    but what it did is it stop my networking n it take hrs 2 find d problm.:mad:
  9. paroh
    paroh Member
    Jul 28, 2008
    850
    0
    16
    As msblaster worm patch is available. but there are some other worm that can attack the network so always keep ur antivirus , anti-spware up to date
  10. piyush.ml20
    Aug 8, 2008
    37
    0
    0
    my avast antivirus is up2date but it didn't help.
Thread Status:
Share This Page
