Sound system wid PC
-=[DDS]=-
G!ZMo FReeK
i Have a Sony home theater system of which speakers i Want to connect iT wid my computer.
But the problem is that, it has 5 speakers.
& iT doesnt have a standard 3.5mm jack, but each speaker has its own seprate wire or 2 wires which would easily fit in the system but its not possible to fit in computer.
So is there any way through which i can connect those speakers wid my computer ???
D
-=[DDS]=-
G!ZMo FReeK
The system i have is of around 10-12 years old which has 345W RMS (120x2W + 35x3W).
The VCD player plays only CD or VCD & doesnt play any MP3 or DvD disc.(since its 10 years old)So i dont wish to use those speakers with my system & use it with my computer
Model no is SONY HCD-VX90AV for VCD system & SS-VX90AV for speaker system (5 speakers).
i Need to buy a new mobo for my AmD x6.
So suggest me which is compatable with that & i will buy that & tell iF sound Card is required oR not ??
Ishu Gupta
Manchester United
Gigabyte GA-880GMA-UD2H or MSI 880GMA-E45 for 5.5K.
It doesn't need a sound card for entry level speakers, but a sound card can enhance quality for higher ennd speakers.
And I don't know anything about that sony speaker. :(
pulkitpopli2004
dere shud be sum AUX on your player.. you need to use dat only.. you will connect your speaker with those 4Pin terminal which you have shown above..
den a wire from AUX will come to your sound card and dis wud with 3.5mm jack.
