[SOLVED] Help Regarding PC Sound output !
TheMost
Simply.. Evolution !!
I started this one *www.thinkdigit.com/forum/tvs-monitors/143415-need-good-led-tv.html
But it will take some more time - 2 weeks or so ..
With these Kind'a TV's, they give 2.1 speakers (If i was right)
Is these Kind'a speakers good ?? Or i have to buy another home theater system - Ready to spend another 10-15 K??
My dad bought a TeKNiKS 5.1 home theater system long back - May be 6 years before .... ( Those Big Sized amplifier and big speakers )
*img69.imageshack.us/img69/3014/11082011261.th.jpg
*img30.imageshack.us/img30/4929/11082011263.th.jpg
*img543.imageshack.us/img543/619/11082011264.th.jpg
*img155.imageshack.us/img155/2720/11082011265.th.jpg
I tried connecting ma PC to this one and i see only 2 speakers in realtek sound manager
*img18.imageshack.us/img18/9541/unledjcm.png
I Know nothing about hardware ..
Should i buy an Sound card for 5.1 ??
Help ya :cry:
( I am planning to Dispose this old 5.1 - Am i right ?? )
mithun_mrg
Re: Help Regarding PC Sound output !
U can change to 5.1 in the speaker configuration since it is Realtek HD it is minimum 5.1
also enable the speaker fill option to get 5.1 output
mithun_mrg
click on the drop down icon beside the stereo there u will find it but i see that option is faded/deactivated what Motherboard u have
*farm7.static.flickr.com/6080/6032012038_97cc4bd0e3.jpg
configurationb by mithun_mrg, on Flickr
TheMost
TheMost
FADED --
So i gotta buy a sound card ???
I have DQ35MP
Edit : I don't see such colored holes in ma PC/amplifier
Just Left-Right
mithun_mrg
So any way ur amplifier supports only 2 channel input which it converts into 5.1 try connecting it to ur PC & see
TheMost
TheMost
Ok leave this amplifier bro - In future if i buy an 5.1 with HDTV - I gotta buy a sound card ??
mithun_mrg
u can get this card available at prime @3K
Auzentech, Inc. : X-Raider 7.1 : World First soundcards for Music, HTPC, and Gaming.
or an Audigy value @1.7K
BTW i just saw ur board uses crappy RealTek ALC268-GR audio codec which supports 2+2 channel audio only i.e 2 front & 2 back so that was the reason of Faded
TheMost
TheMost
Tnx bro --
I will upgrade the sound card when i buy the TV ...
Tnx again ...
[SOLVED]
