Samsung Infuse or other phones under 20k? Expert Help required
Hey ppl, I'm buying a phone for around 20k..
my options :-?
Samsung Infuse (Looks AMAZING)Brand New Samsung INFUSE 4G Unlocked for all GSM in Box | eBay
HTC One V
Sony Xperia U [Dual Core but with only 4GB storage :( ]
Motorola Droid 3 (Dual Core) New Motorola Droid 3 GSM Unlocked @ Lowest Price | eBay
Samsung Galaxy S LCD i9003/i9001
Neo V
HTC Desire S
Huawei Honor..
Please advice cuz it's confusing, Right now Infuse looks the best but single core! If I order unlocked infuse will it work here?
Thanks again..
aroraanant
Explorer
If you buy Infuse you won't get warranty so I think it is one of the major concern and that is the reason I suggest you to stay away from it and also it might not get ICS update(though not sure about it).
Xperia U has only 4GB memory available which is very less according to me for all apps,games,pics,music etc.
Samsung SL has been discontinued a long time back.
Huawei should not be preferred as there are much better options than that.
Droid 3 is also a very old model.You can get much better phones than that.
Desire S, Neo V and One V are very good phones but it is for people with a budget of around 16k.
I suggest you to have a look at HTC Sensation, you can get it for 22k(may be for less with the help of some coupon), its a great phone with dual core processor.And also you will get HTC India warranty in that price.
mitraark
Decrepit
Have a look at Moto ATRIX 2 Specs
22k in Flipkart
Body Dimensions 126 x 66 x 10 mm
Weight 147 g
Display Type TFT capacitive touchscreen, 16M colors
Size 540 x 960 pixels, 4.3 inches (~256 ppi pixel density)
Protection Corning Gorilla Glass
- MOTOBLUR UI with Live Widgets
Internal 8 GB storage, 1 GB RAM
Camera Primary 8 MP, 3264x2448 pixels, autofocus, LED flash
Video Yes, 1080p@24fps
Secondary Yes
Features OS Android OS, v2.3 (Gingerbread)
Chipset TI OMAP 4430
CPU Dual-core 1 GHz Cortex-A9
GPU PowerVR SGX540
Battery Standard battery, Li-Ion 1785 mAh
aroraanant
Explorer
Considering that Motorola is just vanishing from the Indian market as they closed many of their service centers and almost all the Moto Stores I think Atrix should not be considered.
And I doubt how is LG Optimus 3D.
I think Sensation overall for its price is the best option.
Soumik
For 20K, i would suggest Xperia Sola. Decent looks, powerful hardware, good value for money.
If you need more screen estate... increase range and get Sensation.
Also keep chking ebay's Deals of the week. I think last week they had SGSII below 25k... ;) u wont get warranty on it though!
S
sizzlingsaumye
My Budget was 15k..extended to below 20k can't go higher :)
I can put CM9 or MIUI or Custom ROMs, that's not a problem, Did'nt know about warranty in Infuse though. But the phone and screen is brilliant though.
Any suggestions below 20k?
Xperia Arc, U, Neo V, One V, or any other ?
[No LG please]
mitraark
Decrepit
What is your Priority ? 1. Looks ? 2. Power [ Processing ] ? 3. Screen ?
1. HTC One V [ although few will disagree ]
2. Xperia Sola [
3. HTC Incredible S
reddead
LoSt!
atrix 2 or sensation.....
but IMO manage 5k from somewhere and get a S2 insead of regretting later
i wanted to buy a android in the same 20k budget but i have decided upon a S2.....
aroraanant
Explorer
Forget Arc, its better you pick Incredible S over it.
And you can also have a look at One V.
Neo V also can be considered.
