Problems and more problems with Linux
JGuru
@PhreakOutt, You have to be a little patient!! Novell has released Suse 10.1 Remastered Linux. click here
That has many bug-fixes & all the updates. Ofcourse, if you have a 10.1 Suse CDs/DVD,
then install it using it. Get the updates & bug-fixes from the Net.
Those Documentation links should also help you understand Suse Linux better.
phreak0ut
phreak0ut
The Thread Killer >:)
Doh!! Well I downloaded the linux CDs from mirrors from the mentioned site on the official website of SuSE, but I think there is some screw up when I downloaded. Well, I'll tell you what all happened. I had lined up the CD downloads from the site on my download manager. Due to failure in the connection in the middle of the download due to my ISP(BSNL :p ) the download manager stopped and later I couldn't download 2 CDs from the same source. So, for those 2 I chose the remastered download without knowing exactly what it meant, and the rest, I downloaded the normal CDs. You think this has an effect? Well, I'll see if I can download any bug fixes after reinstalling as that is the only option left as of now.
praka123
left this forum longback
you can continue downloads using wget downloader
Code:
wget   -c suse.iso
it will finish the download by d/ling remaining parts.
phreak0ut
phreak0ut
Code:
wget   -c suse.iso
I guess you have got me confused on the above post. I said, I have downloaded and installed the SuSE CDs, but few are the remastered version, and few are the normal ones. Hope this is more easier to understand :)
JGuru
@PhreakOutt, I got your point!! I don't think that will create problem since all
the ISO images you downloaded belong to Suse 10.1 !! Now, get the remaining updates
from the Net.
phreak0ut
phreak0ut
from the Net.
Well, that's a relief to hear. But, when I checked for updates, it shows that there are no updates available. So, I guess I need to wait.
