I have an iball High Speed 4 port USB 2.0 hub connected with my PIII, 512 MB SDRAM machine running on Windows XP SP2. The hub is used to connect a pen drive, webcam etc. It was working fine but recently I had to format and reinstall my windows XP. Now I am facing a peculiar problem. When I connect the Pendrive directly to the USB port, it works fine but when I connect the USB hub to the port and the pendrive to the hub, the pendrive mounts and unmounts immediately and this continues several times. I have uninstalled and reinstalled the USB driver but with no respite. So I cannot use the hub now
Can anyone reason and solution?
