anubhav_har
Hi guys,
Just bought POP:WW yesterday. I installed the game. Whenver i try to start the game I get these errors..
First>>>
*www.stickied.net/files/520fe4a6eefe214ff18d055b55153122.jpg
Then>>>
*www.stickied.net/files/d20b07a98de78496197a9e591bb6df5d.jpg
Please help... I tried ubisoft forums.. no help there... Here is my dxdiag.txt also for your reference...
My specs:
P4 2.4GHz
512MB DDR
Geforce FX5200 128MB GFX Card
DXDIAG:
First>>>
Then>>>
My specs:
P4 2.4GHz
512MB DDR
DXDIAG:
Code:
System Information
Time of this report: 8/17/2006, 13:48:16
Machine name: ANU-A1CE493F917
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.050301-1521)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK Computer INC.
System Model: P4GE-MX
BIOS: Phoenix - Award BIOS v6.00PG
Processor: Intel(R) Pentium(R) 4 CPU 2.40GHz
Memory: 512MB RAM
Page File: 183MB used, 1065MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file nv4_disp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce FX 5200
Manufacturer: NVIDIA
Chip type: GeForce FX 5200
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0322&SUBSYS_13511682&REV_A1
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.8194 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 11/4/2005 18:03:00, 3924096 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 11/4/2005 18:03:00, 3532544 bytes
Device Identifier: {D7B71E3E-4062-11CF-3055-5B3300C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0322
SubSys ID: 0x13511682
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_8086&DEV_24C5&SUBSYS_810F1043&REV_02
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.5530 (English)
WHQL Logo'd: Yes
Date and Size: 3/19/2004 17:32:08, 613244 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24C4
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:38:44, 57600 bytes
| Driver: usbd.sys, 9/4/2001 04:53:36, 4736 bytes
Gameport Devices
+ Intel(R) 82801DB LPC Interface Controller - 24C0
| Matching Device ID: pci\ven_8086&dev_24c0
| Service: isapnp
| Driver: isapnp.sys, 9/4/2001 04:51:16, 35840 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 11/15/2005 18:07:52, 10624 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/3/2004 23:44:38, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 23:28:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 11/15/2005 12:37:52, 40840 bytes
+ Microsoft USB Wheel Mouse Optical
| Vendor/Product ID: 0x045E, 0x0040
| Matching Device ID: hid\vid_045e&pid_0040
| Service: mouhid
| Driver: mouclass.sys, 11/15/2005 12:53:10, 23040 bytes
| Driver: mouhid.sys, 11/15/2005 12:51:06, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay8 TCP/IP Service Provider: BSML - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 20.1 GB
Total Space: 38.2 GB
File System: NTFS
Model: SAMSUNG SP0411N
Drive: D:
Free Space: 11.4 GB
Total Space: 50.0 GB
File System: NTFS
Model: Maxtor 6Y160P0
Drive: E:
Free Space: 11.8 GB
Total Space: 48.8 GB
File System: NTFS
Drive: F:
Free Space: 15.8 GB
Total Space: 25.3 GB
File System: NTFS
Drive: G:
Free Space: 23.6 GB
Total Space: 32.2 GB
File System: NTFS
Drive: H:
Model: ASUS DRW-1608P3S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 23:29:54, 49536 bytes
Drive: I:
Model: LITE-ON CD-RW SOHR-5239V
Drive: J:
Model: PD3450Y NXI824A SCSI CdRom Device
System Devices
Name: Intel(R) 82845G/GL/GE/PE/GV/E Processor to AGP Controller - 2561
Device ID: PCI\VEN_8086&DEV_2561&SUBSYS_00000000&REV_03\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\AGP440.SYS, 5.01.2600.2180 (English), 11/15/2005 18:07:52, 42368 bytes
Name: Intel(R) 82845G/GL/GE/PE/GV/E Processor to I/O Controller - 2560
Device ID: PCI\VEN_8086&DEV_2560&SUBSYS_00000000&REV_03\3&13C0B0C5&0&00
Driver: n/a
Name: Intel(R) 82801DB/DBM USB 2.0 Enhanced Host Controller - 24CD
Device ID: PCI\VEN_8086&DEV_24CD&SUBSYS_80891043&REV_02\3&13C0B0C5&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:38:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:38:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 11/15/2005 18:07:52, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:38:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 01:26:44, 7168 bytes
Name: Intel(R) 82801DB Ultra ATA Storage Controller - 24CB
Device ID: PCI\VEN_8086&DEV_24CB&SUBSYS_80891043&REV_02\3&13C0B0C5&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\intelide.sys, 5.01.2600.2180 (English), 11/15/2005 18:07:54, 5504 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 23:29:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 23:29:44, 95360 bytes
Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C7
Device ID: PCI\VEN_8086&DEV_24C7&SUBSYS_80891043&REV_02\3&13C0B0C5&0&EA
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:38:38, 20480 bytes
Name: Realtek AC'97 Audio
Device ID: PCI\VEN_8086&DEV_24C5&SUBSYS_810F1043&REV_02\3&13C0B0C5&0&FD
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 11/15/2005 12:37:52, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 11/15/2005 12:37:50, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 11/15/2005 12:37:54, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 11/15/2005 12:37:52, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 11/15/2005 12:37:52, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 11/15/2005 12:37:50, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 11/15/2005 12:53:10, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.5530 (English), 3/19/2004 17:32:08, 613244 bytes
Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0024 (English), 2/26/2004 14:23:30, 65024 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.02.0000.0022 (English), 3/19/2004 08:14:32, 14250496 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 2/5/2002 11:24:58, 141016 bytes
Driver: C:\WINDOWS\system32\RTLCPL.EXE, 1.00.0001.0020 (English), 3/19/2004 16:58:52, 6964736 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXSENS.SYS, 5.10.0000.3513 (English), 2/24/2004 08:38:52, 400384 bytes
Driver: C:\WINDOWS\system\crlds3d.dll, 4.12.0001.2002 (English), 11/21/2002 12:37:10, 765952 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 4.12.0001.2009 (English), 8/19/2003 17:06:16, 65536 bytes
Driver: C:\WINDOWS\system32\Audio3D.dll, 4.12.0001.2009 (English), 8/19/2003 17:06:16, 65536 bytes
Driver: C:\WINDOWS\system32\RTLCPAPI.dll, 1.00.0000.0002 (English), 2/9/2004 12:48:18, 155648 bytes
Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C4
Device ID: PCI\VEN_8086&DEV_24C4&SUBSYS_80891043&REV_02\3&13C0B0C5&0&E9
Name: Intel(R) 82801DB/DBM SMBus Controller - 24C3
Device ID: PCI\VEN_8086&DEV_24C3&SUBSYS_80891043&REV_02\3&13C0B0C5&0&FB
Driver: n/a
Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C2
Device ID: PCI\VEN_8086&DEV_24C2&SUBSYS_80891043&REV_02\3&13C0B0C5&0&E8
Name: Intel(R) 82801DB LPC Interface Controller - 24C0
Device ID: PCI\VEN_8086&DEV_24C0&SUBSYS_00000000&REV_02\3&13C0B0C5&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 9/4/2001 04:51:16, 35840 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_82\3&13C0B0C5&0&F0
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:37:48, 68224 bytes
Name: Realtek RTL8139/810x Family Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_81091043&REV_10\4&1A671D0C&0&68F0
Driver: C:\WINDOWS\system32\DRIVERS\R8139n51.sys, 5.505.1004.2002 (English), 10/4/2002 07:34:10, 46976 bytes
Name: NVIDIA GeForce FX 5200
Device ID: PCI\VEN_10DE&DEV_0322&SUBSYS_13511682&REV_A1\4&384EA2E1&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.8194 (English), 11/4/2005 18:03:00, 3532544 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.8194 (English), 11/4/2005 18:03:00, 3924096 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.8194 (English), 11/4/2005 18:03:00, 131139 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.8194 (), 11/4/2005 18:03:00, 573440 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0010.8194 (), 11/4/2005 18:03:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.8194 (English), 11/4/2005 18:03:00, 5394432 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.8194 (English), 11/4/2005 18:03:00, 7307264 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.8194 (English), 11/4/2005 18:03:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.8194 (English), 11/4/2005 18:03:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11009 (English), 11/4/2005 18:03:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0010.8194 (English), 11/4/2005 18:03:00, 229376 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 11/4/2005 18:03:00, 169507 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 11/4/2005 18:03:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0034 (English), 11/4/2005 18:03:00, 35328 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0034 (English), 11/4/2005 18:03:00, 35328 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 9/4/2001 04:50:56 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 9/4/2001 04:50:32 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 9/4/2001 04:50:32 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 9/4/2001 04:50:32 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 9/4/2001 04:50:32 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 9/4/2001 04:50:32 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 9/4/2001 04:50:36 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 9/4/2001 04:50:36 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 9/4/2001 04:50:36 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 9/4/2001 04:50:36 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 9/4/2001 04:50:34 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 9/4/2001 04:51:04 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 11/15/2005 12:53:10 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 11/15/2005 18:07:52 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 82432 bytes
system.dll: 1.01.4322.2032 English Final Retail 6/30/2006 16:41:34 1224704 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 2113536 bytes
directx.cpl: 5.04.0000.3900 English Final Retail 9/30/2004 15:47:14 135168 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 9/4/2001 04:52:08 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 01:26:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 01:26:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:44 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 01:26:44 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:44 20480 bytes
qasf.dll: 11.00.5358.4826 English Final Retail 4/19/2006 02:29:20 201728 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:26 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/30/2005 09:24:26 1287168 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 01:26:46 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 01:26:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 01:26:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 01:26:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 01:26:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 01:26:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 01:26:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 01:26:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 01:26:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:46 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 11/15/2005 12:37:54 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 11/15/2005 12:37:50 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 11/15/2005 12:37:52 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 11/15/2005 12:37:50 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 11/15/2005 18:07:54 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 11/15/2005 18:07:52 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 11/15/2005 18:07:54 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 11/15/2005 12:53:10 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:58 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:26:44 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 11/15/2005 12:53:10 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:26:48 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,3.02.0000.0015
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,3.02.0000.0015
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5358.4826
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5358.4826
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0015
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,3.02.0000.0015
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0015
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0015
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,3.02.0000.0015
Nero Digital AVC Video Enc,0x00200000,1,2,,
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0015
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5358.4826
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,3.02.0000.0015
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Sigma Designs MPEG-2 hardware decoder,0x00800000,3,2,RMMPEG2.AX,
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,3.02.0000.0015
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Daikin VOB Splitter Filter,0x00000000,1,2,dkftransform.ax,
Daikin File Source Filter,0x00000000,0,1,DKFSource.ax,
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,3.02.0000.0015
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,3.02.0000.0015
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,3.02.0000.0015
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5358.4826
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5358.4826
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5358.4826
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5358.4826
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5358.4826
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,3.02.0000.0015
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0015
Nero Vcd Navigator,0x00600000,0,2,NeVcd.ax,3.02.0000.0015
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.02.0000.0008
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,3.02.0000.0015
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5358.4826
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,3.02.0000.0015
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0015
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,3.02.0000.0015
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Nero Splitter,0x00600000,1,3,NeSplitter.ax,3.02.0000.0015
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5358.4826
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,3.02.0000.0015
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5358.4826
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4826
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4826
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4826
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4826
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4826
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4826
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4826
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,3.02.0000.0015
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0015
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,3.02.0000.0015
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1010
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5358.4826
Nero File Source,0x00200000,0,1,NeFileSrc.ax,3.02.0000.0015
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0015
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,3.02.0000.0015
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0015
Nero Digital Parser,0x00600000,0,3,NDParser.ax,3.02.0000.0015
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,3.02.0000.0015
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0015
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,3.02.0000.0015
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,3.02.0000.0015
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.2.2 Codec (1 Logical CPU),0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.2.2 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Realtek AC97 Audio,0x00000000,0,0,,
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,,5.03.2600.2180
Realtek AC97 Audio,0x00200000,19,2,,5.03.2600.2180
