Problem with PC Suite connectivity..
kumars
Guys i am able to surf internet through GPRS by using data cable on my computer.. But when i want to transfer files using any PC Suite (i've 6.8) then software doesn't detect my Nokia Communicator.. My phone gets detected by PC Suite on another computer easily but not on mine!!?
kl_ravi
Do you see nokia phone browser in "My Computer"
Which service pack are you running.
Which version/release of Nokia PC suite
Which mobile are you using
kirtan
may be the connection preferences have not been set.open pc suite and then go to manage connections.u can see the kind of connection preferences like bluetooth,ir,dku-2 etc.check the box with the appropriate connection of your choice.
