Problem with double click as well as enter
sabr_villa
I m having a genuine problem. i hv a pc running ms windows xp, and whenever i try to open any icon by double clicking it, whether in explorer, or on desktop, the property window for that object opens up, ditto for selecting that item and pressing enter. PLZ HELP
gaurav_indian
CG Artist
Maybe you have set the Click event on right click and and the pop menu or properties on the left click.Go to Control Panel and check mouse properties.
R
rahul_becks23
Guest
this basic problem can be solved by checking some basic settings.
R
rahul_becks23
Guest
ummmmmmmmmmm...............maybe some basic tweaks frm Control Panel or some frm menu settings.................OR google it.
Vishal Gupta
Microsoft MVP
Open regedit and for following keys:
HKEY_CLASSES_ROOT\Directory\shell
HKEY_CLASSES_ROOT\Folder\shell
HKEY_CLASSES_ROOT\Drive\shell
Make sure the value of Default is set to none, if its not then change it!
satyamy
Alive Again...
check setting in control panel
if this dosent solve than
update ur driver for Mouse & Keyboard
