Amithansda
I have a core i5,Intel DP67BG mainboard,4GB DDR3 machine with Sapphire Radeon 6870HD with windows 7 installed previously.
I downloaded this Ubuntu 11.04 and ran it as live CD and seemed to found no problem. But I installed it to make my PC dual booting but after the menu choosing at GRUB... The screen goes purple and nothing else I Got another 11.10 DVD borrowed from a pal that removed the 11.04 but the same case happened, no problem while running it from CD, even no error showed during installation, and yet it does not work after GRUB menu.Tried startX in command more, does not work either.
However, I googled a lil bit, and came up with more confused mind Is this happening because my mainboard does not have inbuilt GFX?
One particular suggestion was to enter into Ubuntu recovery mode, and start a safe graphics session, install radeon gfx driver but I don't know how to start safe mode.
I will be grateful if anyone can help me.
