Problem msconfig, WMP10, Volume Icon
Kaushal Hiwarkar
Be Healthy, Keep Smiling
In my system WinXp SP2 msconfig is not running, Volume icon is not showing in systray although there is sound in my system. I have checked volume property,control panel etc and Window
Media Player 10 is not opening. Plz help
Choto Cheeta
Rebooting
msconfig not running means ?? can u be please little more technical ?? like what error do u get whne u try to launch the msconfig ??
about sound problem, try and reinstall the sound drivers for the sound device you have :)
slugger
Banned
2 get d Volume icon back in d task bar follow dis path
Start->Settings->control Panel->Sound and Audio Devices->Volume(tab)->Place Volume icon in the Task Bar(check)
to run MSCONFIG just follow
Start->Run
type msconfig and press ENTER
hopefully it will open d msconfig window ;) :)
if it says file missing or sumthin den download MSCONFIG.EXE and run it from wherever u extract it
