kg11sgbg
@ Forum Friends, I am using my Desktop PC which is quite old,but it's functioning very well.
My CPU is an ancient Dual Core AMD Athlon64X2 4200+(Socket AM2;90nm soi;Windsor Core)
Problem is with the CPU Fan.
I had changed the default factory CPU cooler fan and attached a new CPU Cooler Fan by CoolerMaster model no :->DK9-7E52A-OL-GP
It was running very well for the past seven months or so,but now whenever I switch on the machine,all components spring to life,except the CPU Fan.
I had to manually rotate the fan(I am running my PC,with a side panel open for the past three months,here in Kolkata.The summer heat was unbearable a few days ago,but now despite of weak monsoon setting in at Kolkata.It's much cooler now.)to start it.
The fan seems to rotate slowly at first,but eventually speeds up after a few seconds.
What is the problem?
My interior of the PC is clean as I clean thoroughly with a brush and also use a blower.The CPU Fan is clean.
