PC System without monitor for Video Chatting - budget as LOW
Alive_Hunter
I need to buy a PC System without monitor for my mother for online Video Chatting with relatives.
I have a Videocon LCD TV 19" with HDMI. Planning to use this as monitor.
But not sure will using the TV as Monitor will have any harmful effects on eyes?? PLEASE COMMENT.
BUDGET: as low as possible.
REQ:
Cabinet
Motherboard (with HDMI)
HDD
RAM
CPU
WEBCAM
ASHISH65
Get these Intel dual core g645 -rs 3400.Gigabyte h61 d2h mobo - rs 3000.Corsair 2gb ddr3 ram - rs 650.WD cavier blue hard disk -rs 3400.Iball cabinet with psu -rs 1400. Webcam -logitech 750rs Total - rs 12600.
Naxal
Little Kid
As per price point a view, wont it be better to purchase an Intel Atom based netbook ?
Compact product with everything integrated ?
Anyway, if desktop is a must then try following which is possibly the lowest Budget CPU
Gigabyte GA-D425TUD Combo (Intel Atom D425 + Gigabyte Mobo) @ Rs. 3,700.00
2 GB DDR-III 800 /1333 MHz @ Rs. 620.00
250GB SATA Hard Disc @ Rs. 2,300.00
DVD RW @ Rs. 800.00
iBall / or such small Cabinet With PSU @ Rs. 1,500.00
Keyboard + Mouse (iBall combo) @ Rs. 625.00
WebCam (chose any you like) @ Rs. 800.00
UPS (local) @ Rs. 1,400.00
Should come within 12k. However you have to purchase a D-Sub to HDMI converter since budget PC setup wont going to have a direct HDMI out.
*i45.tinypic.com/2it4jkh.jpg
The following comes with Intel Atom D425 (HT processor, single core) and Intel GMA 3600. It supports Windows XP, so operation is smooth and trouble free with Windows XP.
The Incinerator
Motherboard + Processor - Rs 4446 AMD/MSI AMD 2.8 GHz AM3 Sempron 145 Processor and MSI 760GM-P21 (FX) Mot Combo Motherboard - AMD/MSI: Flipkart.com
HDD - Toshiba 320 GB Internal Hard Drive (MQ01ABD032) - Rs 2700
RAM - Corsair Value Select 2 GB - Rs 750
Cabinet - Generic (iball Foxin etc etc with smps) - Rs 1250
Webcam - ENTER WEBCAM WITH NIGHT VISION & MIC (12mega pixel)- Rs 450
Rs 9596/-
d6bmg
BMG ftw!!
In faxt OP can use a small VGA to HDMI converter
Using D-sub to HDMI or D-Sub - HDMI converter is a very bad idea. They may work or may not. Worse part is even if it work, nobody can assure whether it is going to wkr flawlessly or not. Cause? Analog to digital conversion isn't correctly done with those converters.
Instead get a motherboard with DVI port and use DVI to HDMI cable. Nowadays, most of the descent motherboards have DVI port.
Ascendant001
get intel pentium G based config as suggested in post#2.video chatting requires on the fly encoding & now-a-days h264 is becoming standard for video streaming so a decent processor like intel pentium G620/630/6xx is recommended.monitor or tv,for human eye its same so if one is harmless then other is also harmless.
A
Alive_Hunter
thanks everyone...
I have decided the final configuration:
Gigabyte GA-H61M-D2H Motherboard Rs 3000
Intel dual core g645 Rs 3400
2 Gb DDR3 RAM Rs 650
Toshiba 320GB Internal HDD(MQ01ABD032) Rs 2700
iball cabinet with PSU Rs 1400
Webcam - logitech Rs 750
TOTAL Rs 11900
I am planning to install Win7 on this system. Is 2 GB ram sufficient ?
Pls give ur suggestion n inputs. Planning to place the order today afternoon.
Regards,
AH
Cilus
laborare est orare
N, get 4FB Ram. Corsair 1333 MHz 4GB single module will cost you around 1.2K. It also comes with 10 Yrs of warranty.
Naxal
Little Kid
thanks everyone...
TOTAL Rs 11900
Regards,
AH
Please note,m since you will run with iGP hence a lot of RAM (min i guess 512mb) would be shared by the GPU sub system hence available RAM for OS would be 1.5GB or so.
Pay a little more, (Rs. 1,100/-) to obtain a 4GB DDR-III stick.
A
Alive_Hunter
thanks will increase the RAM to 4 GB..
4 Gb DDR3 RAM Rs 1100
TOTAL Rs 12350
Naxal
Little Kid
^^^ if you are buying locally, try for a 250GB HDD, i guess they are at Rs. 2200 / 2300, that should save some bucks there :p
A
Alive_Hunter
hmm...
changed my mind... now planning to buy a TABLET instead.... with a WIFI router for my cable internet connection.
rs 1000 will go for the Wifi router..
budget for tab : 8000 rs. for a 8" to 10" tab (3G sim not required)
looking for a tab with gud service Center in mumbai.. may be micromax ...
pls suggest a TAB.
Regards,
AH
Cilus
laborare est orare
Please avoid Micromax, it has huge problem list, especially Battery related. Also if you have determined to get a Tablet then create a thread in Laptops and Netbooks section.
Let me know and I'll close this thread.
A
Alive_Hunter
thanks
created an thread Laptops and Netbooks
Cilus@ you can close this thread.
