PC not booting after power cut.
furious_gamer
Excessive happiness
Last Friday, after power cut, my PC is not booting up.
The motherboard light is on, but CPU fan is not spinning. Now, what are the things do i need to check?
furious_gamer
furious_gamer
Excessive happiness
Checked the RAM. Removed modules and installed one by one. Issue is, it is booting one moment at one RAM and next time it is not booting. Same with both RAM modules.
Anything else to check from RAM?
rohanz
What do you mean? It boots properly with one Ram module?
rakesh_ic
I guess the only way is to get your friends mobo and use it for a while and see if your pc is hitting the chance 100%
