P2P Connection Problem
cheetah
Hi Folks,
There is some problem in connecting to Kazaa and Shareaza.It display Connecting and even after 5-10 mins nothing happens.
I am using dialup BSNL Jalandhar.
Any suggestions.
At First the problem is with kazaa only but now both.
theraven
i read ur other thread abt "unofficial guide to ethical hackin"
i read ur alst post
first of all dont scream ( caps is considered screamin )
be nice as far as u can no matter what
and ok since ur a newbie to everything .. fine
let go of it once
but not everytime
as a newbie it IS ur responsibilty to check the forums rules
and forum rules state that u must search before creating a new topic
so as nicely as i can put it .. i ask u to search
look for "http tunnel" or "hopster"
u should get a list of threads
read alib_i's post in any of them ... ull get ur answer
cheers
icecoolz
mostly becos ur dialup connection is too slow...happens often. Also check with ur ISP if he has blocked the Kazaa and other P2P clients. Try this P2P
www.winmx.com
its a small freeware and its p2p. So try with that.
Ethan_Hunt
Your Isp Seems To Be Enforcing a Firewall For Ur Net Connection......Hence Kazaa Sometimes may or may not connect......Using Http Tunnel Or others May not be of that much use to u as i have tried em myself and the Ports Cannot be opened to much extent Which Kazaa requires :cry:.....U can try Out The Latest BitTorrent P2P TEchnology.......It has quite a few Advantages over these traditional P2P's.....Search The forum And Will Get Loads of thread on it and Kazaa As well (Including my own Post that i posted sometime back) :D
