I keep getting error messages such as "illegal disc" does anyone know what's the problem?
I mainly use nero to burn movies, and I'm using a TDK burner with TDK DVD-R, by right it should be compatible.
Can anyone help me?
Here is my error log
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.1.1.0
Internal Version: 8, 1, 1, 0
(Nero Express)
Recorder: <TDK DVDRW1616N> Version: 2.76 - HA 1 TA 0 - 8.1.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <TDK DVDRW1616N >Version: 2.76 - HA 1 TA 0 - 8.1.1.0
=== Scsi-Device-Map ===
CdRomPeripheral : TDK DVDRW1616N nvatabus Port 0 ID 0 DMA: Off
DiskPeripheral : Maxtor 6L200P0 nvatabus Port 0 ID 2 DMA: Off
=== CDRom-Device-Map ===
TDK DVDRW1616N F: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 446MB (457364kB)
Memory in use : 56 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
25.12.2007
UDF compilation
4:45:11 AM #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
4:45:11 AM #2 Text 0 File Isodoc.cpp, Line 6671
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
4:45:12 AM #3 Text 0 File Burncd.cpp, Line 3530
Turn on Disc-At-Once, using DVD media
4:45:30 AM #4 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
4:45:32 AM #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2297887 (510:38.37, 4488MB)
Last address to be written: 2286383 (508:05.08, 4465MB)
4:45:32 AM #6 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
4:45:32 AM #7 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: TDK DVDRW1616N, Media type: DVD-R
Disc Manufacturer ID: <DAXON0> <16S>
Disc Application Code: 64, Disc Physical Code: 193
4:45:32 AM #8 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
Insert the disc to write to.
(Medium in drive: Unknown. Medium required by compilation: DVD R/RW, DVD+R DL.)
4:45:32 AM #9 Text 0 File ThreadedTransferInterface.cpp, Line 785
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286384 (2286384) = #2286384/508:5.9
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286384 blocks [F: TDK DVDRW1616N]
4:45:34 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 986
Prepare [F: TDK DVDRW1616N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682514432, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2286384 | 0 | 0x00
2286384 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
4:45:39 AM #11 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
4:45:39 AM #12 Text 0 File Burncd.cpp, Line 4316
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
4:45:39 AM #13 Phase 24 File dlgbrnst.cpp, Line 1764
Caching of files started
4:45:39 AM #14 Text 0 File Burncd.cpp, Line 4435
Cache writing successful.
4:45:39 AM #15 Phase 25 File dlgbrnst.cpp, Line 1764
Caching of files completed
4:45:39 AM #16 Phase 36 File dlgbrnst.cpp, Line 1764
Burn process started at 8x (11,080 KB/s)
4:45:39 AM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2735
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
4:45:39 AM #18 Text 0 File DVDR.cpp, Line 3245
Recording mode: Sequential Recording Mode for Multisession
4:45:39 AM #19 Text 0 File DVDR.cpp, Line 3401
Start write address at LBA 0
DVD high compatibility mode: Yes
4:45:39 AM #20 Text 0 File Cdrdrv.cpp, Line 10026
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 26127F h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0, Extended part version: 33
Start PSN of the Extra Border Zone: 2FE10 h
Start PSN of Physical format information blocks in Extra Border Zone: 2FFA0 h
Media Specific [16..783]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 40 C1 FD 9E D8 52 00 - 02 84 0E 10 87 88 80 00 .@....R.........
03 44 41 58 4F 4E 30 00 - 04 31 36 53 00 00 00 00 .DAXON0..16S....
05 88 80 00 00 00 01 00 - 06 09 0B 12 A8 88 90 00 ................
07 88 80 00 00 00 00 00 - 08 06 13 0A 0E 08 04 00 ................
09 96 06 0C 0B 70 88 00 - 0A 80 00 00 00 00 10 00 .....p..........
0B 08 18 17 B8 88 85 00 - 0C B6 79 0B B0 33 03 00 ..........y..3..
0D 30 00 D0 00 00 00 00 - 0E 0A 20 3B 37 29 1E 00 .0.........;7)..
0F 50 1D 2B 15 AA B5 00 - 10 88 80 00 00 00 00 00 .P.+............
11 00 00 00 00 00 00 00 - 12 0A 2D 39 35 2B 1D 00 ..........-95+..
13 50 1F 2D 19 98 B5 00 - 14 88 80 00 00 00 00 00 .P.-............
15 00 00 00 00 00 00 00 - 16 09 3A 45 40 2E 27 00 ..........:E@.'.
17 80 21 2E 1F 78 B5 00 - 18 88 8C 00 0C 00 0C 00 ..!..x..........
19 00 00 00 00 00 00 00 - 1A 09 4F 47 46 38 26 00 ..........OGF8&.
1B 70 21 2D 1B 67 C5 00 - 1C 88 84 00 04 00 04 00 .p!-.g..........
4:45:39 AM #21 SPTI -1046 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x53 00 00 00 00 00 22 E3 30 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05
4:45:39 AM #22 CDR -1046 File ThreadedTransferInterface.cpp, Line 1742
Illegal disc
F: TDK DVDRW1616N
4:45:39 AM #23 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1742
Could not perform start of Disc-at-once
4:45:39 AM #24 Text 0 File ThreadedTransfer.cpp, Line 268
Pipe memory size 83836800
4:45:39 AM #25 Phase 38 File dlgbrnst.cpp, Line 1764
Burn process failed at 8x (11,080 KB/s)
4:45:39 AM #26 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
4:45:41 AM #27 Text 0 File Cdrdrv.cpp, Line 11276
DriveLocker: UnLockVolume completed
4:45:41 AM #28 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Can anyone help me?
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
(Nero Express)
Bus Type : default
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Use Inquiry : 1
25.12.2007
UDF compilation
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Revision : 1.02
DAO infos:
MCN: ""
DAO layout:
Sense Code: 0x30
Sense Qual: 0x05
Illegal disc
F: TDK DVDRW1616N
Existing drivers:
Registry Keys:
