pegasus
Nice discussion.
Just adding a few thoughts i had posted elsewhere.
That said, if your laptop is not too heavy on the specs, especially if it has no discrete graphics, you may easily use the same for downloading.
No need to get a netbook then, imho.
Even if you have to spend on a new power brick later, as you are scared it may conk out due to overheating, it may still cost you way less than what a new netbook costs.
We may think a low power desktop rig consumes almost as much power as a laptop does during idle.
But first of all, we need a very efficient PSU.
For an Atom-based rig, pico-psu is a brilliant option but it is not exactly cheap.
The main advantage that laptops enjoy when tuned to consume low power are
- the components are designed to operate at low TDP
- the power brick for the laptop is usually way more efficient than most good PSUs, even 80 plus certified units iirc.
- power management solutions for laptops are more comprehensive compared to usual desktop ones and also more ffective usually
*www.thinkdigit.com/forum/hardware-q/131117-pc-24x7.html#post1275756If you want something just for downloading and are better of using just one main computer, i have seen some guys with powerful gaming rigs use netbooks for downloading instead of assembling rigs with Atom integrated motherboards.
eg. Samsung N128 (was 13.5K)
Some upgrade the internal HDD if they are unable to transfer downloaded data regularly.
Some transfer daily/regularly and some use external HDDs with existing config.
Pros-
- Very low on power consumption-
- efficient
- Very low on heat and noise
- compact and space-saving
- Battery backup
- Free LCD screen+KB+mouse
Cons-
- 1 year warranty
- not upgradeable
But if you want a download rig + media server, i guess the only option will be to get a full-on desktop computer.
But that may double up as your HTPC too.
