Sorry for not explaining problem properly.
I connected both pc's to router and i can ping to each of them from other, now i only need to know how to share files.
what OS are you using.
you also need to know the IP assigned to your system
windows solution >>
Start>run
type
cmd (this brings the command prompt)
type
ipconfig (this gives your IP)
Now to share in windows is simple. go on to the folder which you want to share. right click and select "Sharing and Security", I hope you can do the necessary thing to share now.
Now comes accessing the share.
Go onto another system
open a file browser or so called windows explorer
type in the
\\x.x.x.x, now please I know you are not exactly dumb to copy x.x.x.x which is actually the IP of another system.
pressing enter. let it be and see if the folder you shared shows up or not.
about IP or IP address, your result comes out something like this, so you know what your IP address is.
C:\Documents and Settings\jaiswala>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : asiapacific.hpqcorp.net
IP Address. . . . . . . . . . . . : 16.138.41.94
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 16.138.41.1
Now there are few more things to be explained about sharing permissions in windows. But first check these and let know.
more abut configuring the router also needs to be explained, considering you may not know a few things. but I need to know you were able to share things using what I explained.
---------- Post added at 04:04 PM ---------- Previous post was at 04:02 PM ----------
example continued you need to type the IP(my resul was 16.138.41.94) what you got like this in the browser
