tango_cash
hi ppl
i want to buy a graphic card. i need it for maya, digital fusion, after effect,photoshop.
i have to work on maya vfx i.e particles,dynamics(it needs hardware rendering)
my budget is Rs5000
this is my present config.
Intel P4 2.8gz with H.T
915GAV Intel orignal mobo
1.75gb of DDR1 ram (planning to buy another 1gb stick and replace it with my 256Mb stick)
250gb+320gb sata hdd.
1 Sony DVD writer
1 LG CD writer
Colorsit Power Supply 400w- >>> i have posted about this at *www.thinkdigit.com/forum/showthread.php?t=93744.
i am not planning on upgrading the whole system now.
and i know quadro is the way to go for applications like Maya but buying a quadro is not an option unless one comes for upto Rs5000.
i have some questions-
1. i have been told that if i am unable to use a quadro then i should just use any low end graphic card because a gaming graphic card will not help in maya.so buying a higher end card does not make sense,some have also suggested me to go for the 7XXX series card as they cost only rs2000.how true is it?? and now i am not into gaming that much.(time hee nahi hai)
2.i have heard a lot about 8600gt on the forum.but don't know about the ATI cards in my budget.so pls give some ATI models also.and i have heard it is better to go for ATI models for Maya because it helps in some way.how true is it???
so pls suggest a gfx card for my purpose and mention the price.also if anyone has idea how much 1gb DDR1 ram (prefrebly transcend)costs pls tell.
thank u.
my budget is Rs5000
1 Sony DVD writer
1 LG CD writer
thank u.
