Harsh Pranami
Please suggest me a good external tv tuner card for laptop. I won't be using it with fancy hd dth operators. I'll use it with the set top box provided by the local cablewala. It should be reliable and cheap. Thanks.
EDIT: It will be better if it supports recording too.
