I use an FC6, i tried installing mplayer.i386 using the yum install command, after resolving the dependencies and showing a table as to which all packages it wishes to download, i hit the 'y' key to download, then it showed the below error after downloading all those packages:
Some more info.....
>I had previously installed ffmpeg from sources, then after getting this error i uninstalled it using 'make uninstall' command
>Then, checked if the conflicting files (in '/usr/lib' dir) were deleted, they were.
Even after this, when i try i get this same error, what could be the problem.
Code:
Transaction Check Error: file /usr/lib/libavcodec.so.51 conflicts between attempted installs of ffmpeg-libs-0.4.9-0.34.20070204.lvn6 and ffmpeg-0.4.9-0.8.20070109.fc6
file /usr/lib/libavformat.so.51 conflicts between attempted installs of ffmpeg-libs-0.4.9-0.34.20070204.lvn6 and ffmpeg-0.4.9-0.8.20070109.fc6
file /usr/lib/libavutil.so.49 conflicts between attempted installs of ffmpeg-libs-0.4.9-0.34.20070204.lvn6 and ffmpeg-0.4.9-0.8.20070109.fc6
Some more info.....
