Mouse Problem - Single Click Leads to Double Click
Ironman
My Dragon War Thor Mouse
The One i bought Last Year
has been giving me this problem lately
when i click something , it leads to a double click ,
Is there any way to Solve it ?
6 Months Warranty is Over a few months back , so no point of calling them.:-(
rhitwick
Democracy is a myth
Which OS are you using?
If Windows 7,
Please check this setting first:-
Control Panel-->Folder Options-->General Tab
1>Look for what option is selected under "Click items as follows".
2>Make sure its not "Single click to open an item"
Ironman
Ironman
If Windows 7,
Checked ... Its Not
Go to mouse properties, change to double click speed to fast..
If that doesnt work, its time to dump the mouse and get yourself a proper gaming mouse like the logitech ones..
EDIT: you could try opening the mouse and cleaning the insides if you can handle electronics
icebags
probably the button is done with, my old logitech has this similar issue.
try cleaning the button inside mouse.... u may also try upping the button tip a little, by sticking something to it, that lowering the touch gap with mouse body button, if everything fails.
ram22693
That Elusive 7850 HD
This is probably a long shot but it might work, if you can get your hands on a small bottle of 97% Alcohol, open it up and use a dropper and pour it on the faulty button and try and get some inside the gap between the button. It worked with my Logitech mouse. (Not a gaming mouse) Basically the alcohol evaporates at room temp and takes away the dirt with it.
SunE
Professional Newbie
Open up the mouse and clean the button. If that doesn't work, make a wow to never buy fancy looking cheap stuff again and get something from Logitech G series.
