LED lighting for cabinet
Blue Ripazah
THE CHOSEN ONE
ok guys i just got some stuff
1 rechargeable 4v battery
10 coloured leds (small ones)
5 white leds (a little brighter than small ones)
1 switch
and wire ......now can anybody help me making a circuit in order to make my cabinet glow
SunE
Professional Newbie
Go for this design
*i.imgur.com/ppHed.jpg
The colored 4-pin stars are for the colored LEDs and the white 6-pin stars are for the white LEDs. Make it as long as possible and try to border the top and sides of the inside of the side panel.
saurabh_1e
teh tech saviour!
Why didn't you bought the led used in modding/styling cars a 1 foot strip retails for 100-200 bucks depending upon quality. they are much much better then the loose ones and can be directly attached to the 4 pin Molex connector and get easily fitted with a double sided tape.
they are much smaller in size and much brighter.
Blue Ripazah
Blue Ripazah
THE CHOSEN ONE
firstly i dont want to connect it to pc's power supply.......secondly i had that option in my mind but then i wouldnt get coloured leds that were just single colour
Go for this design
thnx ...will post pics soon once done
planning for 'diwali light decoration' in ur case ? :D
heheheh :-D :-D :-D :wink:
na just making it look better
actually i am free for the next 2 months so trying to do some creative work
saurabh_1e
teh tech saviour!
Your wish but strips of different colour are available with size varying from 10-20 cm....
plus you can have a switch worth 30/- to switch the leds on and off
