Dark Star
1'st whenever I use to close Dolphin I used to get this error
Well it was solved by using this command for a short period of time.. But the problem is still there
Now whenever I try to cut/copy past any file in NTFS partition I get this error ..
Here is my fstab output
and this is my fdisk -l output
Please help me I never faced this problem in Ubuntu I had even used NTFS-config but same error every time
Also my Firefox fonts have become exceptionally huge.. Even using CTRL + Mouse Wheel doesn't fix this problem permanently I am using 2.0.0.12
*www.imgx.org/pthumbs/small/5439/snapshot2.jpg
Also I get error while unziping archive .. I guess I don't enough privileged.. though I have added enough from USer Settings
How to install Styles [same as gtk themes of gnome], Icons , KDM themes manually ? cause using Wizard gave error that xyz archive is not correct .. Blast Kubuntu
In the end Just tell these problem are with Kubuntu or in every KDE distros././ I mean installation of icons and all.. \
Regards
Code:
Unable to save bookmarks in /home/shashwat/.kde/share/apps/d3lphin/bookmarks.xml. Reported error was: Permission denied. This error message will only be shown once. The cause of the error needs to be fixed as quickly as possible, which is most likely a full hard drive.
Code:
sudo chown shashwat /home/shashwat/.kde/share/apps/d3lphin/bookmarks.xml
Code:
Could not change permissions for
/media/sda5/KDE_Crystal_Diamond_2.7_Kubuntu_Mod.tar.gz
Code:
# /etc/fstab: static file system information.
# -- This file has been automaticly generated by ntfs-config --
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
# Entry for /dev/sda3 :
UUID=2984bfc4-e289-417b-829e-5870488b4fbf / ext3 defaults,errors=remount-ro 0 1
# Entry for /dev/sda1 :
UUID=CCE44E48E44E354C /media/sda1 ntfs-3g defaults,umask=007,gid=46 0 1
# Entry for /dev/sda5 :
UUID=15BEB5322F467B42 /media/sda5 ntfs-3g defaults,umask=007,gid=46 0 1
# Entry for /dev/sda6 :
UUID=0BCF489D1C56ABAA /media/sda6 ntfs-3g defaults,umask=007,gid=46 0 1
# Entry for /dev/sda7 :
UUID=331259EB02AB33BF /media/sda7 ntfs-3g defaults,umask=007,gid=46 0 1
# Entry for /dev/sda4 :
UUID=18a87f5a-5851-4fc4-a53c-8764e7fcd1a4 none swap sw 0 0
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto,exec 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto,exec 0 0
Code:
Disk /dev/sda: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x0dd6c6bd
Device Boot Start End Blocks Id System
/dev/sda1 * 1 3187 25599546 7 HPFS/NTFS
/dev/sda2 3188 8287 40965750 f W95 Ext'd (LBA)
/dev/sda3 8288 9607 10602900 83 Linux
/dev/sda4 9608 9729 979965 82 Linux swap / Solaris
/dev/sda5 4406 5737 10699290 7 HPFS/NTFS
/dev/sda6 5738 8287 20482843+ 7 HPFS/NTFS
/dev/sda7 3188 4405 9783522 7 HPFS/NTFS
Partition table entries are not in disk order
adm, admin, audio, cdrom, dialout, dip, disk, fax, floppy, games, lpadmin, netdev, plugdev, powerdev, root, scanner, users, video
Regards
