is thr any setting to get maximum volume for mp3 ring tones in 3230 nokia..
sdivya
hi every1,
how can i get a maximum volume for the mp3 ring tones in my nokia 3230 mobile. is that while converting to ogg play format i should go for the best quality-big sized file? i use dBpowerAMPP-OggVorbis-SSE2 , dBpowerAMP-OggVorbis-aoTuV, dMC-Mp3-MPEGSuite2000-Encoder-CLI for mp3 audio and SmartMovie_v2.76_with_PC_Converter_S60 for video for conversion. is there any better s\w available? is nokia pc suite better than these?
mani234
i too use the same
i too hav the same probs i think 3230 max speaker vol is low compared to other models
dIgItaL_BrAt
u can try upping the volume of the original file using mp3Gain,and then converting it.
that would compensate for the phone's low volume.
dOm1naTOr
Lowering the bitrate would increase the playback volume in 3230.[only in that], but the quality will be reduced. Then after that boost the volume with mp3gain. It would now be double louder than a 6630 or a 6680.
