HELP: URGENT: mysqld, iptables, many problems!!!!!!!!!!!!!!
nileshgr
httpd was configured long ago. I had changed the location of .pid file from /etc/httpd/run to /var/run
Two days ago, i saw many files in /etc/httpd/run
I deleted all of them and now there is Sound Problem, mysqld won't start, iptables wud give errors, much more..... How do i solve this???????????? This is urgent. Please help!!!!!
The Sound Error is:
The volume control did not find any elements and/or devices to control. This means either that you don't have the right GStreamer plugins installed, or that you don't have a sound card configured.
You can remove the volume control from the panel by right-clicking the speaker icon on the panel and selecting "Remove From Panel" from the menu.
For now my pc is running. But with lot of problems. :oops: :(
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
mediator
The Unknown said:
sabko mujhe chidane mein he majak sujta hai kya? please tell a solution.
Ayila!! :shock: :shock: :shock:
Why wud I wanna do a heinous crime like that? Just telling u to reinstall coz u deleted some files from ..../httpd/run...so it means apache directory. U may try it! :oops:
nileshgr
nileshgr
mehulved said:
First of all check the logs. And if you don't understand them, post them here.
lol, i'm sayin pid files and you r sayin log files?? What relation they have in common??
