Help.........problem with chrome !!
Hey guyz !!:rolleyes:
help me out , i downloaded the chrome on the day of its launching it was working fine till last week , but from the starting of this week it is behaving unresponsively, it is not opening anypage and shows error:
[FONT=arial,sans-serif]
This webpage is not available.
The webpage at *www.google.com/ might be temporarily down or it may have moved permanently to a new web address.
*thinkdigit.com/forum/data:image/png;base64,R0lGODlhDAAMAMQAAAAAzOjp7lVmrezt8Zmlztja4c/R2Gx9te/x9srN1PHz9+7w9Ofp7eHj5/f4+vDx89bZ3t3g5eTn6/P19/v8+/////39/fj4+P///wAAAAAAAAAAAAAAAAAAAAAAAAAAACH5BAEAABgALAAAAAAMAAwAAAVFYEUIZEkSolCt7CocKgsALdnOrGXLdEVdJMdsOHyQJkTigLRAKBQzxWIQIDGugRlD0miQIoXwDEKGCEaGhHqdeKVMJVQIADs= More information on this error
[/FONT]
I have had reinstalled it 3 or 4 times but all in vain !!:confused::confused:
help me out !!
gopi_vbboy
hey don;t go for chrome......wait for few days for stable version.
If u need speedy browsing i suggest u to go for opera..
im sry ...i donno why u get that error...but remember there are lot of fixes still goin on for chrome......so better wait for some time
gopi_vbboy
Configure ur Firewall to treat Chrome as Web-Browser......Ur firewall may be blocking the connection......
Try scanning ur system with SpyBot.
Make sure nothing is blocking Chrome like Antivirus filter in Nod32.....somethin like Scanning the data by Antivirus......Turn them off
if nothing works wait for some new version of ChROME
comp@ddict
EXIT: DATA Junkyard
Chrome is in Beta, bound to be some problems..
USE Opera or FF3, or even IE8 beta 2 ATM, change l8er when Chrome will b'come a full version
(long time, my gf's gona get old by then, and i thought she waz already old)
P.S>_ i hav no gf.
dheeraj_kumar
Legen-wait for it-dary!
^^ Whats better and whats not, depends on you.
In my opinion, FF and IE should be dumped, and you should use Opera. Chrome is like windows... most the people wont like it before SP2, because it just isnt good.
gopi_vbboy
Don go for IE if u prefer speed .......IE sucks in speed but is more secure comparitively and has lots of support...Go for IE7 not IE8.........don;t try beta version unless u are a geek......beta is for testing
