help me on wine problem
saurabh kakkar
D i s t i n c t l y Ahead
hi
I had to remove wine due to its improper working on my ubuntu 7.04 it was not showing help option
uninstaller was not working properly now i want to install wine again correctly whats the process ?
also in windows .exe is the executable file responsible for running whats in linux ? plz help this noob
QwertyManiac
Commander in Chief
In Linux, executable files work on the attribute basis rather than extensions. 'x' is the attribute which means executable. If a file has +x attribute attached or assigned to it, it is treated as an executable. Some applications come as .bin, though. Extensions don't matter in Linux, the file permissions (+r, +w, +x, etc) do. Right click on a file > Properties > Permissions to know more.
praka123
left this forum longback
install wine using apt or synaptic gui.for latest wine there is a repository.add below repo to ur /etc/apt/sources.list and save exit;apt-get update(in synaptic press reload)-these all when internet is connected.
Code:
 # Bleeding edge wine packages
deb *wine.budgetdedicated.com/apt feisty main
adding repo is explained in below thread(though dont use if it is for edgy)
*ubuntusoftware.info/repos.html
infra_red_dude
Wire muncher!
i'd rather recommend wine from the official ubuntu repos than the "bleeding edge wine packages". they always tend to crash for me.
for installing the stable version. simply goto the terminal and type "sudo apt-get install wine"
saurabh kakkar
saurabh kakkar
buddy i have done the same but it cause a hell lot of problem like installer
was not working properly ,there was no help option also conif was giving
problem thats Y i have asked for a proper nd stable method
