Help Help Plzz Help?
smile
Hi..... Guys :)
I have Youtelecom Brod band connection and speed is 96 K bps . The problem is when i enter any websites address it doesn't connected only after three to four times i refresh then it connects :(....it happens both in IE & FF , I scan my system , reinstall Firefox , infact when i connect to my laptop i am not having any problem only with my PC:mad: . Please help me to solve my problem :confused:
slugger
Banned
you telecoms connections r down in mumbai at the moment
edit
did not read the PC-laptop thing
my bad
Amir.php
Flying Visitor
I remember that few days ago you have post the same problem.
I think it is not your browser or system problem. I will be better for you to complain this problem to your service provider- Youtelecom.
Amir.php
Flying Visitor
I Think you have some problem to contact with your internet providers.
Well do a simple work. if in your home or any of your friend have modem+gprs enable mobile such as reliance, idea, airtel etc then try to make connection with your laptop.
assume data cable will provided by the mobiles.
if you have same problem then it will system problem otherwise you must report to your internet service provider.
good by.
Roadripper
its a spyware cum adware which is blockin and is in the system 32 folder ... use SPybot + trojan remover + spywre doctor + nod32 ... this is wat i used and cleaned it.. it ll work out fine once ur done ...:p:p
Beta Waves
Hi..... Guys :)
Hello my dear smile :D you have posted the same problem here
*www.thinkdigit.com/forum/showthread.php?t=90745
And again you have created a new thread ....:confused:
smile
smile
@ g_goyal2000 - I think i dont have DNS issue . My ip address is Obtain automically .If i had DNS problem then how come its working fine when i plug in my laptop and use internet:D
