100.dx
NBC(Next Bill Candinate)
in my bsnl order's section
it shows
Order Status - Future Dated
wht is thi means?
an wen i check my usage for apr2008
it shows no usage found for this month
wht is all story is?
i giv app to bsnl last month for plan change 900UL and yet i cant get tht my plan is change orr not?
wen i ask to customer care center they tell ur plan is change
but as i listen tht in 900UL we only get 256kbps speed
but i m not wrong thn i m gettin 2mbps speed/120mb dwd speed
i m in big prob guys
i already dwded near abt 2gb in 2 days as i think my 900 plan is running
pls solve problem
it shows
wht is thi means?
pls solve problem
