144
I am unable to browse certain sites ( Actually alot of sites ),..
Some sites just dont load. It remains at about 3% loaded ( on Opera ),.. for eg : *vray.info does not load at all.. it remains like that for a long time. Then the usual error message is displayed while other sites are just normal.
I am sharing an ADSL over a LAN. I have checked my TCP/IP settings. My DNS server settings are correct. My IP and default Gateway(the IP of the router) are correct.
My ISP requires a Proxy and I am using it.
Facing the problem on Internet Explorer 6.0 / Mozilla FireFox 1.0.3/ Opera 8.0 -- All three browsers.
My System Config : P4 2.4Ghz, 256MB DDR SD , 40GB 7200rpm HDD, AGP 4x GeForce 2 400MX 64 MB VRAM, Optical : ASUS DVD RW +,
Windows XP Professional with SP2, Firewall turned off. AVG Antivirus - free version.
