facing some problem in using card reader
jacques
Hi dears,
I am using OS professional 2000 and having 6670 nokia. I just got the generic usb based card reader. I am unable to use it. After installing the driver computer shows the 4 icons for removable disk. when i click on the disk. msg comes "plz insert the disk". Plz help...........
I am not able to insert the card. can say do not know that in which slot card to be inserted....
montsa007
~Bulletproof Monk~
try all the slots 1st of all there are 4 slots
2 are tooo big 4 the mmc so 4get them they are in the left side 1 below the other when u hold the reader slots facing ur side then the slot in right on top is used 4 mmc ok?
or else when not connected to pc try insertin ur mmc coolly in each slot then take it out if it does smoothly u have found the slot
*dont exert pressure
