Entry level gaming laptop with decent battery life in 30k range
kartikoli
Busy!!
Hi I am looking for entry level gaming laptop as my Sony SVE1513BYN (Link)with HD 7650M is having some trouble and I am in need to replace it ASAP.
The laptop is used mainly for office purpose with google spreadhseet been used most of the time along with youtube but I would be using it for games as well (GTA 4, mafia 2 etc... May be GTA 5 if it can run)
Battery life is quite important so and would be preferred. I have checked the other thread and most of the suggestions were in favor of 840M so please suggest accordingly.
I have a desktop with 280x so I can always use it for high end games and can settle for low/medium settings for a laptop.
3yr warranty would be really awesome so please suggest in 30k range (I can increase my budget if its worth it).
Forget gaming laptop in 30k, even 60k laptops aren't good enough for gaming.
Best you can get are entry level laptops like Lenovo G50-45 with R5 M230 which can't run games on anything above 768p, low-med settings.
Laptops with 840M start at 40k+ range.
Minion
Asus X550LDV-XX623D
Dell Vostro 3546
Both comes with Nvidia 820M GPU You will not find 840M within 30k.
kartikoli
kartikoli
Busy!!
Thanks a lot for suggestions but looks like this lenovo laptop is inferior to my existing Sony laptop (gaming).
If I increase my budget to 40k then do I have any good choice?
Nope, that GPU is crap. 840M is way better than it.
http://www.notebookcheck.net/AMD-Radeon-R7-M265.109394.0.html
can't play these at least
Civilization: Beyond Earth
Thief
Assassin´s Creed IV
Need for Speed: Rivals
Saints Row IV
Company of Heroes 2
Metro: Last Light
Crysis 3
Hitman: Absolution
Max Payne 3
kg11sgbg
Thief
Assassin´s Creed IV
Saints Row IV
Company of Heroes 2
Metro: Last Light
Crysis 3
Hitman: Absolution
Max Payne 3
That site also lists any other AMD mobile GPU's as craps.
At least one should not buy merely by claiming a site's authenticity.
Nvidia 840GPU(mobile) and AMD R7 265M benchmark tests come very close to each other. It is very laughable to say that by few extra points a 840GPU is superior to AMD's R7 265M GPU. The most important and stunning aspect about your explanation is that you seemed to be very biased in favour of LENOVO and NVIDIA. As equally your biasedness goes against DELL and AMD GPU's or AMD as a whole.
Brother please don't get deviated from logical true facts,which might not be reflected in some biased tech site as notebookcheck.net!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I'm not referring to benchmarks, I never depend on benchmarks. Look at the framerates. Those 10 games I mentioned will not run on the R7 M265 while 840M will be able to run them with the same settings and resolution. R7 M265 can't even perform at 830M levels, why should anybody prefer that over 840M and that too for a 50k laptop? You should've checked all the facts clearly before pointing your finger at me.
But for gaming, every other DDR3 gpu is crap, be it from nVidia or AMD. If you can find a laptop with R9 M265X from ANY OEM in India under 50k, I'd gladly recommend it.
http://www.notebookcheck.net/AMD-Radeon-R9-M265X.114535.0.html
That being said, if an OEM keeps overpricing their products ridiculously, I'll be biased against it. That Dell laptop isn't worth anything over 40k.
AMD GPUs aren't bad, the manufacturers are reluctant to use them in laptops. Then there's the various driver issues which were reported in the past concerning switchable graphics not working on laptops with AMD gpu's.
kkn13
Cyber Genius FTW
Im afraid Im gonna have to disagree Ive got a Dell Inspiron SE 7520 with an AMD 7730M and it handles everything perfectly none of the issues you said
Dell may overprice but its with good reason, the design etc is better for heat and runs smooth on battery
a notorious issue with Lenovo and Nvidia based laptops is that they struggle to run games and heavy programs on battery ,you can check this out in the y510p thread or just google it
from what ive used, Nvidia gpus have compatibility issues and lack of proper drivers
I have a vaio and a dell
my vaio has an Nvidia gpu,updates etc are hell after the next gen comes out
im using Leshcat drivers on my dell with an AMD gpu and it can run Skyrim on high at 45fps and doesnt cross 70c
the only place where ive seen performance take a toss is when playing watch dogs because evil corp - Nvidia owns the engine used to make the game and decided AMDs should run it slow
every other game runs perfectly on AMD
dont generalise please
well amd vs nvidia apart, nothing wrong with AMD gpus at all but the best in that range is Z50,Z510P
thats my unbiased opinion!
Also DDR3 Gpus arent crap at all,ive never seen mine even stutter or lag at all
it can output skyrim on high to my 1080P Sony LED and doesnt even hiccup
if you have the budget,GDDR5 is a no brainer but that doesnt mean DDR3 is crap at all,it runs fine unless you want to play in 4K res
