@soyab0007
Yes.. It does make difference. These are the plus points if you have additional sound card than onboard Chip
1. Everything sounds better.
2. You will have more High Volumes than onboard. Onboard sound is weak.
3. With sound card ,Voices will be crisp and Clear compared to onboard.
4. Headphones sounds way better
5. If speakers are above 1000 rs they def'ly need sound card for better experience especially the ones you mentioned.
6. It might save some resources from processor.
7. It's never waste of money.
