suyash_123
Techno Freak
hey guys, i will be purchasing a new PC (desktop) .
I always go for latest but which comes in my budget.
I have 25000 to 30000 budget
I have budget of 20000 for just Cpu.
So i went to a computer dealer and ask for Core2quad processor price and Its compatable MOBO
But that fellow said that don't take core 2quad , it gets over heat very quickly.
it requires a very Low surrounding temp.
if u have AC in your house then its ok but if not then it get problem of over heat .
and due to overheat problem no Branded PC Like Dell,Hp etc are launching there Core2Quad series as they know that the Surrounding temp in india(pune) is High.
I said that's b**l s**t . Intel must have take care of it.
But I Have little thought in my mind, that is why Branded PC are not taking out there core2Quad range in INDIA
Please any buddy Using Core2quad processor. Tell ur reviews on it
am i right to buy Core2quad.
Also with that Please tell me
Which Core2Quad I should buy There are numerous range
(I want visualization technology in tht processor to as Xp mode of Win7 works only on Vt tech)
Also Suggest A goodMotherboard for same .
Thanks in Advance
Thanks in Advance
