Hi there ,
I wish to upgrade my smps( Navtech 450 W) and as regards that I am clueless as to whether my new SMPS would be compatible with my present home UPS ( Microtek 810 VA) , ie suppose I go for a 1000 W cooler master SMPS , do I have to upgrade my Home UPS / Inverter also .My home UPS / Inverter is of 810 VA rating .
I do not wish to upgrade my UPS/Inverter and as regards that I wish to know , what is the maximum wattage of SMPS which I can use on this UPS , without further upgrading my system config.
My system configuration is
AMD Athlon 64 2800 +
ASUS K8SMX( on board sound and graphics)
160 GB SATA hard Drive
2*512 MB Ram
CD writer
DVD writer
The reason I wish to upgrade is that my computer hangs a lot and I have been told by local experts that this is several times due to two reasons viz
1> Pirated copy of Windows XP and
2>Unreliable / Local power supply like Navtech et al .
I have replaced the pirated XP with a genuine one and I found that now my system doesn't hangs as frequently as it used to when it was running on a pirated version , but still once a day say it still hangs.
My most important concern is that How can I permanently get rid of system hangs and if riddance is not possible than what all can be done to minimise it ?
Thanks and regards.
2*512 MB Ram
CD writer
DVD writer
Thanks and regards.
