yehmeriidhain
hi,
Well from this morning i have been formatting my hard disk's first partition C: again & again to install my windows properly but i encountered a few very new problems :
1: my formatting stops at 39% & to raise it up by just 1% i mean till 40% it takes ard 5 minutes ( hell lot of time ) ... Tell me whether i need to replace my hard disk ...????
2: now my institute's website isn't opening in internet explorer .. although i have configured it correctly ... Is there some problem with my installation of Windows XP ??
3: my Yahoo! messenger isn't working on No Proxies option ...& on every other option else than this it works indefinitely SLOW!!! ....... Do tell is this a windows problem & believe me reinstalling messenger wont help me ever ..i have tried it??
4: Last but not the least after formatting my hard disk same partiotion for more than 7 times my LAN card is permanently detected ...as with LAN speed of 10 Mbps ..instead of 100 Mbps .. & it doesn't matter whether i connect my LAN cable or not it always says the same ... LAN speed connected 10 Mbps ..i mean it is always connected .... It's an RTL8139 chipset ...which in general has it's driver with windows itself it need not to be installed again & again .....
Tell me people wat's the problem......my hard disk.............. my installation or.................. it's simply me ..i'm feeling sick in my mind now!!
Thanks! in advance!
Thanks! in advance!
