Re: Advice for High end Gaming cofig (only cabinet + internal parts) - budget 1-1.2 L
Corsair F series is SATA II(discontinued).Force 3 and GT are SATA III but have BSOD and reboot issues even after latest firmware updates.
The OCZ SSDs currently with latest firmware have no problems.
It was a problem with the SF-2000 series controller for the SSDs, over which the OCZ firmware is based. Almost all SF-2000 series models had the problem, not just OCZ.
If you can, get the MAX IOPS drive as it has double the lifetime (same chips used as Vertex 3 Pro). It is also faster
Make sure that you update the firmware before using the SSD. You should have no problems then.
BTW did you make a mistake by mistake? Cuz you say galti se mistake ho gaya lol.
EDIT: forgot to tell you, IMHO the Maximus IV Extreme-Z is worth the money IMHO. What makes it special is that the "Extreme" ROG mobos from Asus are always the best in class ever since they moved on to the red/black theme.
You get the best mobo out there for overclocking. You even get Bluetooth in the extreme mobos. Temp and volt sensors, external OCing through cellphone/Shitphone/shitpod/other PC. mobo handles sub-zero temps like a dream.
