A odd problem with Zotac Gt 210
xTreme_rck
I hav a Zotac GT 210
with it i have played crysis crysis 2 at 1366*768 at medium settings and it was handling All HD Blurey Films well but now a days it was unable to handle any games like DFX 2 !!! And even HD videos !!!! Dont Talk about Other Games Please...
I have used
ASUS GTS 450
Zotac GTX 560 Ti Amp
MSI GTX 560
on the same machine (those were from my friends to test for a month and ZOTAC is my bro's.)
But when i get back to my old GPU for quite a day it was performing well but after a week it has just gone down.
I have cleaned all components... Formatted the OS thrice but nothing helps me Please provide any solution to play the old games until my new GPU comes.
I have seek help on that in this section earlier
My config is
i5 750
ASUS P7P55D
CM GX 650 Watt
CM USP 100 CAB
Logitech MX 518
MS Sidewinder X6
desiJATT
Away from Forums, Again!
Could you be more specific on what exactly are the problems you're facing? Like video stuttering, frame skipping in HD videos and dropping frame rates in games or stuff?
Tech_Wiz
From the things we can only say that your GFX has gone bad and you have to wait till your new one comes i.e.3-4 days max.
@ OP - what's load temp of the GPU you are getting ?? may be a you need to re-TiM the gpu.
