rose tamang
Hi, Guys!!
My System Configuration:
Questions:
Please help!!
"Rose"
- Celeron Processor: 3.06 GHz
- Motherboard: Gigabyte 945
- DDR2 : 512
- Seagate HDD: 80 GB
- DVD ROM: LG
- My system is in the top floor of a concrete building. The temperature is really high in the room because of the continual exposure to the sun.
- I checked my cooling fan and found that the thermal paste has gone dry.
- During Bios set up view: CPU temperature displays 55 degree
- CPU Fan : Runs Smoothly.
- I've formatted the C: drive with NTFS and that went smoothly.
- Windows XP SP 1: During set up, prompts for some * .dll missing and to insert WIN XP CD
- I've three WINXP CDS and I try with them one after another but the problem goes the same. But when I hit enter key after 5 minutes the set up goes smoothly and stops loading the set up files after few seconds. I've to follow this procedure until Windows installed completely.
- Now for the first time the XP loads and prompts to create users.
- After the Windows is installed completely. My computer restarts again and again. It loads but restarts before the Log In screen displays.
- I used UBCD to scan for viruses but the software found to be 25 months old.
Questions:
- Is it my room that messing up with the system?
- Is there any free antivirus program that can be used in command line?
- Is it the problem with my XP cds?
- About the thermal paste, what quantity of it should be pasted on the heat sink? What's the procedure? What's the precaution to be taken?
Please help!!
"Rose"
