5.1 audio system buying guide!!!
Discussion in 'Hardware Q&A' started by dinesh_mettur, Dec 23, 2006.
Thread Status:
  1. dinesh_mettur
    dinesh_mettur New Member
    Jan 13, 2006
    239
    0
    0
    TamilNadu
    hi dudes
    am planning to buy 5.1 audio system for my pc so could any one suggest me a good brand
    my budget is 7k
  2. codename_romeo
    codename_romeo Romeo + Lucifer = ME
    Oct 15, 2006
    989
    13
    0
    CREATIVE INSPIRE 4.1 Rs2400
    CREATIVE INSPIRE 5.1 Rs3800
    CREATIVE INSPIRE 6.1 Rs5100
    CREATIVE INSPIRE 7.1 Rs6700
  3. dOm1naTOr
    dOm1naTOr Wise Old Owl
    Mar 2, 2005
    4,152
    9
    0
    shhhh!!!!! on a sniper point
    Logitech X530 is a good 5.1 set with total of 70W rms. It has got dual neodimium drivers in each satellites. But it lacks an auxilary out and a wires remote. The volume control is on the front right sattelite.
    Another gun 5.1 set is from Creative, the T6060 73W rms system, with tweeters on front 3 satellites and its got a wired remote with a headphone jack or the auxilary out and an auxilary in and also the vloume nd bass control.Its pretty gud if not better that X530.
    If u have around 10k to spend, the logitech Z5300 THX system will be yours. It has 280W rms and has THX logo, that means it reproduces all sounds as it is meant to be heard. Its really nice and could stand with any high end home theaters as far as audio quality is concerned, though the power is also not that less.
    U can get the Creative 7.1, thr T7700 for 6800/-. Is has somewhat 90W rms and got a wired remote like that of T6060. Its also gud but not so appealing on looks and not that gud for listening music, but gaming xperience on a 7.1 is gr8 that on a 5.1.
  4. Tech Geek
    Tech Geek Wise Old Owl
    Sep 21, 2006
    1,602
    18
    0
    Cyber Hell
    ALTECH LANCING SPEAKERS
    VL-251 5.1 Rs4000
  5. shyamno
    shyamno New Member
    Aug 10, 2005
    650
    1
    0
    Kolkata
    I think if your budget is around 7k then you must try Altec Lansing 2.1 MX5021.You will forget your 5.1 experience..I al not confirmed about ots price but it will be around that..before buying any 5.1 please please have a look at that..
  6. dOm1naTOr
    Mar 2, 2005
    4,152
    9
    0
    yes the Altec Lansing 2.1 MX5021 is up for 7.3k
    its really nice nd has around 90W rms nd it could beat most 5.1 im music listening, but gaming on a surround system is superb, nd no 2.1 system could deliver it.
    If u can spend 7k for a 2.1 then anyhow extend the budget(maybe even by doin some theft or pocket picks) nd get Z5300THX for sub 10k.
  7. Tekky
    Tekky New Member
    Apr 9, 2006
    26
    0
    0
    INDIA --> NEW DELHI
    @aravind_n20 me too lookin forward for the same thing....
    so wat do u REALLY suggest ? which of those 3...m much more into music...
  8. dOm1naTOr
    Mar 2, 2005
    4,152
    9
    0
    anyday ill suggest only the Z5300THX. It has 280W rms nd that MX5021 has only 90. 90rms for a 2.1 is not bad but not as gud as 280w for a 5.1.
    If u have 10k to spend then go for it or if u have tight budget nd could at max extent upto only 7k then get MX5021. If u want gud sound nd some music .low on budget then get X530
  9. Kiran.dks
    Kiran.dks New Member
    Apr 3, 2006
    2,494
    91
    0
    Pune, India
    Go for Creative or Artis. Both are good.
  10. sabret00the
    sabret00the New Member
    Aug 6, 2006
    699
    3
    0
    Calcutta
    what about Logitech X530..heard that it was better than the inspire series...
  11. vivekbabbudelhi
    vivekbabbudelhi shadow hunter
    Mar 8, 2007
    267
    0
    0
    guys, where have u bumped up
    23-12-2006
  12. keith_j_snyder2
    keith_j_snyder2 Rising ApocalypsE
    Dec 25, 2006
    1,492
    0
    0
  13. sagardani
    sagardani Lost in LOST
    Nov 19, 2005
    165
    0
    0
    Pune
    You have to go through this thread before you go to buy....;)
  14. Count Dracula
    Count Dracula New Member
    Oct 30, 2007
    138
    0
    0
    Keith and Sagar, you bumped a months old thread,that guy must have probably purchased the speaker system yet.
  15. keith_j_snyder2
    Dec 25, 2006
    1,492
    0
    0
    Damm! i do this all the time! Sorry!
Thread Status:
Share This Page
