Xp Hibenate Problem Pls Pls Help
Ankush_is_here
hello guys i have facing one problem pls help me .
i m using xp sp2 when i click on hibernate it will hibernate well but when i turn on my pc it will not resume WELL AFTER SHOWING RESUMING MONITOR DISPLAY DISSAPPEAR i.e there is no display on monitor pls help me what will i do to hibernate my pc.
and turn off and restart were working well.
i have also tried new window but after some time this problem wiill build up in new window too.
navjotjsingh
Can you post a list of programs running while you try to hibernate(via Hijackthis log file)
Also try disabling and reenabling hibernation feature.(This will delete your old hiberfil.sys file in C:/.
Ankush_is_here
Ankush_is_here
only firfox and fdm and bluetooth bro
already tried renabling
RCuber
The Mighty Unkel!!!
I guess its a bluetooth driver problem. Disable the bluetooth service and then try hibernating you system.
Choto Cheeta
Rebooting
Delete the Hyberfil.sys file...
Go to Control Panel, select Performance and Maintenance, Power Options, Hibernate tab, and uncheck the Enable hibernation box reboot...
Now once again follow that method to enable the Hybernate, now try again...
