Wireless Internet speed Vs Wired internet speed
Ishu Gupta
Manchester United
The diff is
1) Worse/Higher ping on wifi
2) Slightly lower speed on wifi depending on signal strength.
You can just replace your router with a wifi router to get wifi internet.
D
dr_karasheed
I think you will need at least 5mbps or more speed to watch hd stream. Correct me if I'm wrong.
You are very near to my calculations or assumptions. It will need at least 30 Mbps to see a streaming video on a 21" TV, and even more for a 42" LCD Tv. In the meanwhile I was also searching Forums from other sources. You will be having my feedback
