the_player
Hello ,
I have 3 questions :
1> I have Transcend 1GB JV30 USB pen drive . After installing Win XP SP2 my pen drive does not seem to get detected.
Prior to SP2 installation , my drive used to function normally.
My Computer does not show the removable disk drive ;therefore I cannot read my drive contents ; but my drive LED flashes . Also an icon appears on my system tray (this is the "Safely Remove hardware " icon ).
Also I can stop the drive normally , as one does .
At my office where I work , my drive gets detected normally , and functions perfectly.
What could the problem be ? I tried reinstalling Win XP SP2 and the motherboard drivers , but in vain .
Someone Pleeeeeeeeeeaaaaaaaaaaassssssssseeeeeeee help.
2> My friend purchased the same drive , he has another problem :
His system is a brand new system of Compaq Dual core 2 , ticking @ 2.80Ghz and 256MB RAM . His drive gets detected properly , but he cannot Remove the Hardware , when he attempts to do so , Windows flashes the message "The device Generic Volume cannot be removed now . Try removing the device later".
If he has to remove the drive , he has to shutdown the system first , after which his drive LED goes OFF and he can remove the drive.
His drive detects and functions normally at his office. What could be the problem ?
3> One more friend of mine has Mercury 845GL mainboard with P4 ticking @ 1.7GHz , 512MB DDR Transcend memory . Does his system have USB 2.0 port , and is it compatible with Transcend JFV301GB pen drive ?
